Did you say a little muddy
Geez Dulagarl, what happened ?
I hope everything else is ok with your Forry mate.
Great job with the clean up too I must say
Clutch got stuck engaged: motor was running but no power.
Hopefully with a good clean it'll be just like new.Car is getting box dropped and clutch / flywheel area cleaned. All OK it seems.
My nightly fix: whack the left hand side halogen headlight from dull to working before setting off. This is a common issue, is there a fix to this?
Sounds like a loose connection
Another possibility is that the bulb filament is broken, but not completely - i.e. has partially re-welded itself. I have had this happen.
For the second it took me to change to highbeam I completetly shat myself. Not a fun experience.
^ Gidday Pigs
Sounds as though the bulb isn't seated properly, the connector is loose/not seated properly, or the connector has loose/dirty clips.
