NachaLuva
Product Developer
Yeah, that would complicate things!
Gidday PS
This is what I have done. It works properly - i.e. only comes on with HB, and nothing else.
Wiring diagram:
Full size printable image:
https://canopuscomputing.com.au/gallery2/d/18123-2/E-510_JAK_2015-_6278294+copy-Large.jpg
Wiring layout for engine bay:
https://canopuscomputing.com.au/gallery2/d/18127-2/E-510_JAK_2015-_6278295+copy_Large.jpg
Sorry about my crappy drawings, but I hope this helps you.
Some photos of the very roughly fitted light bar ...
It has to be adjusted for level and square yet.
Hi Ratbag,
I understand the point of using 2 relays to separate the current drawn for high beams from the current drawn for the light bar. That part makes sense to me.
What I don't understand is why aren't you running 1 battery wire straight to the light bar and switching the other wire only?
Why do both go through the light bar relay and not just 1 to keep design simpler?
I get the feeling you're shoehorning positive switching into a negative switched car...
Anyways, if it works...
Ratbag,
I need your help to understand the diagram (sorry I am really not good with electronic)
- the "40A supplied Relay" in your diagram is the relay that comes with the light bar?
- from your diagram, your second relay is a normal open 4 pin relay?
- In the wiring layout for engine bay diagram, the cabin switch and fog switch are linked by a "P" - what does this mean?
- In the relay that comes with my (20in) lightbar, there are numbers (87, 30, 85 and 86) at the pins and how are they correspond to W, B R1 and R2 in your wiring diagram?
sorry that's for it at the moment...
It's done.
It works.
The light bar's bloody fantastic value at $89.96 delivered. Thanks go to PauSum for putting me onto it.
Here are some photos of the (almost) completed setup.
