It really is finished!
While grovelling under the dash to put the light bar switching wires through the grommet between the clutch and brake master cylinders, I think I might have discovered some switch blocks in behind the internal fuse block that might, just might, be the phantom light stalk terminating connectors. By this stage, I really couldn't give a rat's **** what they are!
I also fed the UHF aerial in the other direction to where I still have to make a permanent mount for the Oricom unit under the fog and driving light switches.
All the wires have been run, armoured where necessary (almost everywhere ...), insulation tape around all joins, zip locks around everything, etc, etc, etc ...
I have also very roughly aligned the beam of the light bar vertically - spirit level on the paving, then across the front of the light vertically ...
Put the grill in, and made up a new piece that attaches the front/top radiator support bar to the top of the grill.
Bunnings sell a really, really tough ribbed plasticised sheet 1m wide - $21.95 p.m. . I made this out of that.
I will also make a rear bumper protector, side shield from the bull bar to the radiator, under guards for the side from the bull bar to the mudguard liners, bottom fill piece from the rear/bottom of the bull bar to in front of the sump guard.
Ateday, yes just use your current (pardon the pun
) relay. RBs trouble was working out how best to wire up the relay in the first place, you've already done that part :biggrin:
The relay that came with the one I bought is weird. I know that now. However, so is the wiring in my model car ...
Must be nuts but I just ordered one.
Now where the hell will I fit it?????
Gear Acquisition Syndrome (GAS) strikes again ...
facing backwards to deter tailgaters.
Yeah ... Unfortunately just a little, tiny bit illegal.
Now to finish the coffee I started at around 1300H, and go a get some cat meat and stuff at Woollies ...
Photos later ...
