Gidday NL
There is one flaw in that suggestion, mate - It
doesn't work ...
The series II SG has (very) different wiring.
I have just now solved how to make it work.
The relay main earth (heavy black lead) and the relay trigger wire (light gauge red wire) need to be connected to the two high beam wires.
[Edit] The heavy red wire from the light bar relay is connected to the postive battery terminal. [end edit]
The light bar relay switching earth wire (light gauge black wire) is not used.
Put these two wires onto the high beam wires (B -> B and R -> R) via two vampire connectors onto the high beam light leads.
The light bar will now switch on only with high beam, and is off at all other times.
To avoid overloading the high beam circuit, it would seem to me to be a good idea to have a secondary dumb slave relay between the light bar main earth wire and the battery. That is, the new relay is connected via the vampire connector, and switches the main light bar relay earth to the battery.
This relay should be able to be wired conventionally, but only one side of the load (earth) needs to be connected (or should be??). Probably best to leave the other side disconnected.
I will have to dig out some relays I have in the garage and finesse this side of the arrangement.
Each side headlight assembly is on a separate 15A fuse in the series II SG. The headlights are 60W (HB) plus 55W (LB) and the parking light is 5W. Total 120W = 10A. The light bar draws 126W (but apparently draws less than this in terms of amperage - about 8.5A, IIRC), but is also partly connected via the heavy gauge lead to the positive terminal of the battery, so hard to do a straight sum to work out what the amperage on the relay ground connector is adding to the overall amperage being drawn on the circuit. The multimeter I have can measure up to a 10A current in both AC and DC, so it can be measured but not without disconnecting the vampire lead.
What a Heath Robinson method of connecting this!! I am still amazed that it works at all ...
