Kevin
- Jul 28, 2008
- 7,154
- Sydney, Oz
- MY'03
- Forester
- A/T
Not on that BP5 model. I was looking for bleeder valve initially as it would be very, very handy but it seems that the engineers removed it from the design. Cheers.Good idea @ABFoz Do you also use the bleeder valve on the heater hose or did that change with your model?
Yes, that one is very handy. Older models have it still. Even newer models from other manufacturers do not hve them anymore. I think it is similar to the fate of the transmission dip stick. New cars don't have them anymore.I wonder why - may have been the accountants that removed it! I find it very handy when changing the coolant.
Awesome! what are you going to do with it?I got a '95 EJ22 full option Legacy for free !
There's not much that can be done with a 4EAT, unless it's a direct swap in the same model, as the TCU communicates with the ECU. Some people have done a cross model 4EAT swap but that was with a lot of electronic/electrical surgery.Strip it ! I will keep the engine and whats around the engine plus some suspension parts but not the transmission as it has a 4EAT.
Well there you go. I never knew that was there! how do you open that, just with a screwdriver?Do you also use the bleeder valve on the heater hose or did that change with your model?
Is the 4EAT doing OK? Just curious as before being called bulletproof, Subaru had a fair share of growth pains with the 4EAT development. Cheers.
This brings the output of the alternator up to 140amp from the XTs 90amp. In preperation for a dual battery setup
Ooh... I think Ruby Scoo just got a new item on her parts mod list (it’s pretty small these days...)
Wow air suspension that would be cool to modify some for offroad maybe.Yes, it works just fine. That Legacy even has oem pneumatic suspension but it doesn't work, there must be a leak somewhere....
