I pulled one of the swaybar links (drivers side) off yesterday to see if it thats what was causing the problem.
Once it was off, I took it for a good drive & Bob's you uncle, no more knocking![]()
Problem solved
Now I just need to replace the front swaybar links with a different type
I think I'll go with the same style that I have for the rear, as they have worked & served me well for the past couple of years
And all without the knocking too I must add![]()
Great to hear mate! My forester has about 8-9 different knocking, squeaking and rattling sounds :lol:
Problem solved
Off my P-Plates!!!![]()
Haven't put it back on yet. But I can say that the bushes are still in as new condition thoughGood to hear that.
These things can be flaming hard to track down sometimes ...
It's not being caused by a loose/worn bush in the sway bar is it?
Or just a loose nut/bolt?
Have you tried re-connecting it and torquing all the nuts to spec and see if it still knocks?
When I do put it back on, I'm going to flip the bolts the other way round. I'll see how it goes then.
Well today tried to swap wheels with Davidovs gen 3 Outback due to him breaking yet another rear strut. My 15" rims just don't clear his front brakes by about 1mm
His 215/70R16 tyres do fit on my Forester though and raised it about 1.5"Wish I could of taken it for a drive with them on, hell it would of bee gutless. lol
Need to make a trip upto Geraldton 450km each way, on Thursday and since davidovs Outback, my Forester and the L are undrivable for long distance one of them has to be fixed asap. His OB has a busted strut, he has since taken out the lift and with the large tyres it is literally undriveable as you can't even turn the whell half a turn without rubbing. My Forester has done a rear wheel bearing and I don't want to do a 1000km trip without it getting done first. Since I have my last exam tomorrow I can't get it sorted then
The L-Series has done a front wheel bearing but is luckily a DIY job that can be done tomorrowI just hope it will make it on a trip that big in one day..... Hoping it wont over heat or break down or what ever. Should be right though once the bearing is done
going through a bad stage just like memy engine light popped up for about 5seconds while driving last night the second time in about 2 weeks, dont know why everything is running fine but i will have to fix it very soon, hoping its just a sensor of some type. and also a stuffed rear strut also
did the large wheels fit the rear of your car?
Yeah I think this is just a bad year for me, but the way I look at it is everything I fix or replace atleast it should be good for another 100,000km+.
Yes the tyres just fit with some slight rubbing on the spring perch but they do fit and could be driven like that. So yes 215/70R16 do fin under an SF. 215/75R15 would fit without rubbing and have about a 2mm gap :iconwink:
Check for codes. Is this is your 99 Foz? Connect the two green connectors under the dash, turn the key to acc and count how man long and short flashes there are.
do you have stock rear struts? because looking at mine i dont think i would fit the 70's only 65's
yes i need to check codes, have exam today so busy and going home tomorrow so i might just go to my mechanic when i get home. it runs fine and has only popped on when it was very cold outside so im guessing it would be some sort of sensor
Yes stock struts, they are new KYB's but for a stock SF NOT SG.
Fair enough, I have my last exam todayProbably just a sensor worn out..
hoping just a worn sensor. hmm seeming i have a stuffed rear struts when i replace the rear, does that then mean i will be able to run larger wheels like yourself?
