The pressure in gas struts is measured in Newtons, apparently. The ones in my trailer are now 1,000N! Presumably, this is Newtons per square centimetre. That equates to around 1,450 psi!! S'truth, Narelle!
Day before yesterday, I grovelled under the A-bar of the trailer and hit all the nasty bits (i.e. all of it ... ) with cold gal primer. Wattyl appear to be having a batch problem with theirs, so I exchanged the two dud cans for some other brand FTM.
Yesterday I hit all that stuff with a top coat of charcoal hammertone. Rotten place to work, as upside down, and have to get in far too close for "aesthetically pleasing" spray painting, so runs and doobles all over the place
:rotfl:.
The mighty tag-along is not really meant to be some dream machine camper trailer (you know, the kind that some people - not me! - drop $30-50K on :iconwink:
... ). It is meant to be a serviceable, pretty robust trailer with comfortable accommodation - particularly the lying down part!
I have noticed that the axle is sitting slightly further back on the P/S. The clearance between the tyre and the rear of the mudguard is only 40mm, compared with 60mm on the D/S. It looks as if the fish plate for the axle U-bolts is eccentric, front to rear (rough measurement with tape measure). The current front to O/S of locating hole is about 50mm+ and the rear measurement is about 40mm.
I will check this against the D/S plate with a small Engineer's rule I have.
Just reversing the P/S plate F<->R will make them much more even. So even though I feel thoroughly RS today, I am just about to go and do those things.
Because the axle is attached under the springs, I can do this without jacking the trailer up. However, I also want to see if I can slip a bit of steel between the rear of the slipper springs and the chassis, and see how this affects the ride height/tyre clearance of the trailer.
An opportunity to try out my 750 mm air jack, perhaps
