I have a leaking tie rod end. I thought I needed to replace the whole assembly, over $100 genuine. So I can replace just the boot? How easy is it to do?
Also have an oil drip coming from the plastic timing belt cover, passenger side...must investigate that....
Must also tighten the handbrake too, better read up on the manual lol
The rack boots are an easy swap out with a rack puller. jack up the car slip in an a stand,
1. pull out the pin in the top of the ball joint
2. take off the nut
3. use a puller to pop the arm out of the wheel assembly
4. mark the threat for the steering alignment so it all gos back in the same place.
5. use two spanners to take off the rack end then unscrew the nut on the piston arm.
6. cut off the old boot with a sharp knife and put the new boot on with clamps or zip ties depending on what sort you buy, and put it all back together and put the pin back in. If it wasn't before bend it up over the nut when your done.
* If you dont have a rack or a gear puller then take off the caliper, disc and steel shroud. leave the nut on the top of the threads but upside down not to damage the nut or threads, and hit it with a rubber mallet, if that doesnt work stick a scissor jack under the side of the arm to redirect more of the force of the mallet hit. They can be very stubborn or easy to get out, a puller is the easiest way not to damage anything and about $40 from super cheap auto. boots are about $12 from bersons, and a cable tie tentioning tool helps to get the ties nice and tight in the small space.
If the rack is leaking it might of done a seal and need them replaced the boot just stops dust dirt and crap getting in and damaging the seal on the hydrolic pison and dirt damaging the ball joint.
The leak on the timming belt cover is more than likely the crank seals have perrished. Mine did the same thing have the mechanic change them when you get the timming belt done if its close to being due, otherwise keep an eye on the leak if it gets realy bad have them and the timming belt done early. Easiest way to find out whats leaking is to give everything a good clean up and look around in the morning and night before leaving to see where the oil is leaving a line.
And taza has got it with the handbrake, if you have a knuckle couple of small extentions and a deep dish socket (1/4" stuff) you dont even need to take off any trim, but the trims only a couple of screws.
