jf1sf5
- Aug 5, 2012
- 2,089
- Switzerland
- '97
- Forester
- Manual
A hand winch makes you become a better driver off road....because you don't want to use it !
Is the low position the flattest it can get, meaning when it completely collapses or fails, it's just at 4.5 cms lower than high?
I think your system is good because if the system collapses, it will be around the stock height, which is still trackable, unlike full airbag ones which collapse to the ground.Yes, exactly.
So at low car feels like on normal oem shock same stiffness and all ? Good on corners ansd such? And on high in dont have suspension travel anymore but it have clearance? Sounds cool .
And those are not too much angles for those cv axles?Yes, in the "low" position, the Forester behaves the same as a stock Forester with a 2" spacer lift. In the "high" position, the air piston pushes the spring up by 4,5cm so I can't get full compression but because its air, the weight of the car on diagonals is able to push the piston down which probably gives me all the travel back. You can see it on the video at 3:52.
Man, the older 80's Subarus completely dominated the course with ease.couple old cool subarus and newer ones vs audi and vw passat ...
