I have begun a new project with the Forrie. A gearbox and rear diff upgrade form the centre of this project. I had a spare gearbox lying around doing nothing and so I decided to have it overhauled. It will get a stronger first and second gear set from a later model gearbox. 3rd, 4th and 5th will be from a turbo box, with 5th being the tallest available 0.738 ratio. Final drive will be 4.44:1. All gears including low range will be shot peened for extra strength. I did the maths and while in gears 1-4 the gearing will be shorter, with this extra tall 5th it will cruise at lower RPM in top gear.
But the interesting part of the project is really a project in itself. I recently purchased an R180 rear diff from an MY10 WRX. I want to try and install a locking centre. The centre itself is expected to be an e-locker. Originally intended for use in a different brand of car, the plan is to see if we can get it to fit inside the Subaru R180 housing and mate it up to the axles and crown wheel. Initial investigations have shown there to be some issues which need to be sorted, but we are quietly confident we might get there. Whether or not I go the whole R180 rear end, or run a hybrid R180/R160 rear end I have not decided. While I am at it, I will look at installing a GD Impreza rear sub frame to see if that will improve the handling
Having a locking centre and rear diff, plus a torsen front diff, should give the car some pretty impressive capability. We just need to see if we can do it.
