Completed wiring and post references
Previous photographs about my installation are here:
My wiring diagram:
https://offroadsubarus.com/showpost.php?p=86924&postcount=87
The rat's nest wiring:
https://offroadsubarus.com/showpost.php?p=86947&postcount=94
The relays mounted and wired with colour coded wire etc:
https://offroadsubarus.com/showpost.php?p=86957&postcount=99
New photos.
Using Holden owner's screwdriver to open internal cabin lining for wires after removing the grommet between the brake and clutch master cylinders:
UHF aerial fed through the grommet:
Back of cabin driving light and fog light switches showing the jumper wires from the driving light switch to the terminals on the fog light switch to connect the DL switch to the instrument panel light circuit (fog light switch on the right):
Feeding the DL switch wires through the grommet, using needle nose pliers to expand the hole sufficiently:
Back of cabin switch showing armouring from the switch to the firewall:
All wires fed both ways through the grommet:
Opening the firewall loom clip:
Armoured switch wires terminated and sealed with insulation tape at tunnel connector near relays:
Armoured cables tied to other parts of the normal wiring loom to keep them out of harm's way:
Armoured switch wires fixed using existing firewall wiring loom body clips:
Cabin switch panel to the right of the steering column, all powered up :biggrin: :
Photos of light bar in action to follow ...
