just above the first mark from cold
That's where mine used to sit all the time
, just a little bit of a gap between it and the first marker, less than a quarter of the space between first & second marks (ish)
From the OBD, that spot on the gauge covers from about 85ish to 95ish -without the needle moving noticeably at all, possibly even lower starting temperature..
Other things I've found:
My thermostat opens at about 89 degrees, you can see the temperature drop on Torque Pro when it does it. How long it takes between thermostat opening, the sensor reading and thus actual temperature it opens at is anyone's guess, I presume they're not right next to each other.. (diagrams show that, even if I haven't actually worked out where to look because, thank you internet, they are conflicting.
Fans kick in at low at about 92-93.
Fans kick in high at about 96-97.
^ I presume they're controlled by the ECU coolant sensor (? are there two in a MY05 Forester?)
It's funny, I've had this in my head for a while, never even contemplated that it might be useful information.
Is it?
(I've got some sort of weird disability when it comes to spelling gauge. My brain just doesn't cope with it and I always end up with a u or two in weird spots.)
