All this positive CVT stuff is really good to hear. I was getting ready to move to a less exciting manufacturer due to my mechanic calling them a "time-bomb for a gearbox". He was probably referring to the earlier models.
I definitely agree with Rally, gotta do some testing on that hill.
The new SK Forester is beginning to grow on me. I wonder if this has an even better CVT than the SJ? Also interesting is that the SJ range had a standard CVT, plus a high-torque CVT for the XT and diesel models...
Makes me wonder if they are all high torque now for longevity.
Yes, I’m not surprised you want to do something about the bumper.
I would have tore it off on first impact if it didn't leave its guts hanging. Need to map out the vitals before we cut it. Want maximum clearance and protection, plus some flare lol
Cvts get as much hate as cars offroading. I've heard of manufacturers (such as Nissan) that have horrific system. Turning the key is like pulling the pin out of a hand grenade. It's gonna blow, only a matter of time, and everyone associates all cvts with the worst case scenario. But if you find your way past the pure bias, you'll hear, time and time again, that Subaru is pretty much leading in reliable and usable cvts. Thought they were cool for on road application when I first heard of them, and was admittedly worried for it in an offroad environment. But I've pushed mine up hills, over rocks, through off camber bends, into mud, and sometimes all the above at the same time. Not a problem. Cvts are actually better than their automatic and manual counterparts in terms of weight, and fuel efficiency.
If you compare them to other vehicles in their class, they are definitely more car then SUV. Yet more capable) I'll admit, once I got a taste of what the car could do, I pushed it past what I actually plan on using it for. I just couldn't help it. Everytime we saw an obstacle we thought would stop it, it proved itself. It shocks us everytime we take it out, none stop. Definatly a proven offroader that can hold its own, but I still get people that put me down cause it's a car, and I think they don't want to see a stock $17k car walk past their $60k highly modified rig, be it a truck, jeep, or whatever. I love it on the road and off. And I was a hard core truck guy, never owned a car.
What you said is similar to what I said 21 years ago when I first drove a BG off road. I was a proper 4x4 enthusiast and even raced the Bighorn. I just kept getting surprised with my SG even to this day.
There is a quote, "CVTs: mechanics hate them but engineers love them." Engineers keep on getting better efficiency results as they improve or revise their CVTs.
I would assume that the SK has a TR580 but I will double check that with the local dealership. It would be nice to have the much beefier TR690 but they are only limited to high torque models like the late Forester XT, the WRX and the 3.6Rs. The TR690 has a monstrous chain.
The TR580 is popular though as it has a much more efficient design. The forward and reverse clutches in front of the pulleys, eliminating drag in neutral and park, whereas with the TR690, they are at the rear. There is no input clutch and secondary planetary gear anymore with the TR580.
The first release of the TR580 had problems with the secondary pressure sensor, creating a false code in the system and thereby stalling the car, and the leak in the torque converter seal, especially in cold weathers. Under warranty, they issued a much more tolerant seal to deal with extremely hot and arctic conditions. The first revision came out in Dec 2014, after the said faults were detected, but many 2015 models have already been produced . Once a leak is seen around the bell-housing, owners are obliged to drop by their dealerships or authorised mechanics for the replacement. Oftentimes, fluid level is too low breaking the whole transmission and that's why they just get replaced. TR580 revisions (and even with the 4EAT) are made at least once a year and the revision version is seen on the transmission code by the bell-housing. I have been told by the head mechanic at the local dealership that the latest TR580's chain is much beefier that last year's to handle torque much better, allowing the installation of Dual X-mode and eliminating the need for the algorithm to search for the correct ratio, although I have no proper confirmation yet.
Some dealerships are wrong when they say that the CVT fluid does not need changing. They just want people to buy new ones every three years. At 120,000km, the internal filter driven under normal conditions should already be on its limits. The recommended oil change interval for Lineartronic CVTs that go off-road is every 45,000km. NZ New CVT Subarus are serviced at the dealership and some are already at the 250,000 km mark with the original transmission. People that buy CVT Subarus second-hand from Japan are not as informed as the ones buying brand new so many would go beyond GVM and tow extra-large boats and caravans. We all know what will happen to their CVT chains in those conditions.
When planning to drive the car harder, it's recommended to upgrade the control module and valve body for aggressive lockups. This is much easier to do on a TR690 as the valve body is at the bottom of the transmission whereas the TR580 is at the top for more efficient delivery. I am OK with the TR580 as I like the friction plates in front of the pulley but if I am going to drive harder with it, I might as well have the valve body and control module upgraded. It is cheaper to do regular maintenance, not go above GVM and not tow houses than to upgrade the said parts, though.
Upon opening a Nissan CVT's sump pan, the metal pieces/shavings are just all over the place. Belt failures are common to those that use the conventional design (Van Doorne).
I am also getting more and more good info on the reliability of these transmissions, especially from CVT specialists. Many are fans of the chain and I think it's just good engineering to have placed such instead of the Van Doorne. I think having CVT on a low-cost from 1985 pays for low-cost long-term research. Cheers.
OK so it seems that an SJ XT has a more robust TR690 from the sounds of it. If, theoretically, I were to upgrade to a CVT Foz then I'd definitely want to go for the last of the XTs before their extinction, only problem is I'd be going for a 80-120,000 km 2nd hand one.
Subaru backing them up with warranties is great if buying new, but I guess I may need to accept that I should keep a couple of grand (I heard $7k) in the mattress for a CVT rebuild as (knowing my luck) I'd end up with an XT that has been thrashed.
Right now, I would buy an SK if I could afford it. I think I am willing to try my first CVT. Never thought I'd say it. Crikeys, it might even happen this year....I just need to get a minor ding fixed (father inlaw reversed into a light pole) and then I might put the SF GT up for sale.
Faaaark, I was so close to getting a Pajero. Funny how facts/knowledge/information can influence people.
Thanks [MENTION=15881]ABFoz[/MENTION] some great info!!
What's the Van Doorne design?
In some markets, they say that the TR690 does not have problems, except for the fact that the turbos are driven hard, straining the transmission more. There was an issue with CVT pump oil leaks causing failures but an upgraded gasket change can mitigate it. Some just re-torque the cover to a slightly higher spec to eliminate the leak.
If you are going to go TR690, some dealerships have good mechanics that can certify the transmissions and do the proper servicing and inspection. Otherwise, you can visit MRT Performance at Rhodes, NSW. They know what they are doing.
The SK though, I know many people now that have been drooling over it as it is the car of the year in many international markets. Dealerships keep on saying that the CVT in it has the revised and upgraded components, whenever they are asked about the recalls up to the 2015 models.
I did my research as my mother wants to get an XV but in red. She went off-road too in her younger years.
Thanks @ABFoz some great info!!
Welcome.
Here are the images of the Van Doorne belt:
iu
iu
Subaru CVT chain
iu
Comparison between the Van Doorne belt and Subaru's Lineartronic CVT chain. The far-right should be the one for the TR690.
iu
Cheers.
In the off road world, it’s not such an issue. Not really the place for dyno queens. In the wrx world, the cvt box can only handle mild increases in engine output. Something to keep in mind if you want more from your XT, or any turbo Subaru with the cvt.
Thanks ABFoz very interesting!!
Welcome!
Based on mechanics' and tuners observations, the stock torque that the TR690 can candle is 400nm max and still, even with abuse or hard driving, they still get some chain slippage close to that maximum. To be able to increase the tolerance, a CVT valve body and control module upgrade is necessary. It's recommended to do the CVT upgrades first before tuning.
about airing down5psi vs 30psi . night and day difference30psi5psiworks even for those who maybe dont have any mud or soft ground
^Yes. The king of off road for many is the tyre pressure. In [MENTION=16269]Dirt Trek[/MENTION]'s case, there isn't that much sidewall to do the airing down. That's the same dilemma I faced when I had the 215/55 R17s and I had to do mud and rocks.
we should be here not for arguing but about learning more about it. i duno other way to learn about other cars then watching other ppl doing that on their cars with their mods on their areas. im sorry if i make someone here offended or angry. thats not my knowlendge or guessing but just seeing how others drive and what works where and why it works.
all cars are limited to their own stuff but we can still use that on some level to work give us result.
just learned how ****ty new forester 2019 x mode is , well ****ty because ESP is allways on there. and those 2 modes of new x mode doesnt work at all. i think from now on we will get just subaru cars for moms drive shoping nothing more. new forester cant drive uphill at all, well up snow hill at least as ESP allways on , yuou can just choose 2 x mode modes but there is catch there, x mode turns off when it reaches 40km/h speed, but you reaching that speed not on straight road just by spining wheel in middle of hill and then car changes mode turning x mode off and car wont go any further.
and new forester doesnt do snow drifting too. again saw video , thats proof. EPS allways on and it doesnt give any torque to rear at all. and they tested older foresters who could still drift with VDC and x mode. but new model cant.
so there is no hope to get anything off roady from new subarus anymore i guess. too much sensors too many cameras and restrictions.
i looked at that new forester and thought that my car would do there better with fully VDC off if needed of VDC on when situation needs it . same forester their where ok maybe until 2015 or 106 but i think newer ones just doesnt go anymore.
Yes. Different terrains and even climates require different techniques and setups. The symmetrical AWD itself is good enough and that's why it has been off-roaded since the 70's especially in the PNW. My SG5 on stock suspension does well in mud, sand or snow, where the drivetrain excels.Regarding the SK Forester or newer Subarus, we may actually be on the stage where we are purists and are somewhat restrictive in understanding modern versions. This happened in the 90's as well, when people were using high riding 4WD Subarus and then the BC and BG Legacies came into the market. They were really against the car being too car-like. Perhaps we can give it a few more years so people can understand better how the new systems work? Many of those making videos of the 2019 Forester are not exactly off-roaders. What if it is driven by an off-roader like when @Red XS drove a CVT coming from an older model?
Regarding Dual X-mode, this channel tested it and it seems to be giving more torque to the wheels than previous ones.
[ame="https://www.youtube.com/watch?v=6U4WLc2V-LMI"]2019 Forester Dual X-Mode Explained and Real World Test #drivingsportstv - YouTube[/ame]
I think the regular X-mode is good enough but the extra torque/wheel spin gave it even more go.Regarding going sideways, I know the Ascent is supposed to behave like the other Subarus even though it has a bit more torque with the turbo but it can still play in the snow. Check out this video from Canada:
[ame="https://www.youtube.com/watch?v=uFlHdz3Mx6I"]Subaru Ascent: Why we love to SEND IT SIDEWAYS! | and the Pros and Cons! - YouTube[/ame]
It is supposed to have the same traction management as the Forester but somehow the driver is able to let it have fun sideways. Cheers.
Welcome!Based on mechanics' and tuners observations, the stock torque that the TR690 can candle is 400nm max and still, even with abuse or hard driving, they still get some chain slippage close to that maximum. To be able to increase the tolerance, a CVT valve body and control module upgrade is necessary. It's recommended to do the CVT upgrades first before tuning.^Yes. The king of off road for many is the tyre pressure. In [MENTION=16269]Dirt Trek[/MENTION]'s case, there isn't that much sidewall to do the airing down. That's the same dilemma I faced when I had the 215/55 R17s and I had to do mud and rocks.
Speaking to Dave changing the valve body won’t help. However, you can go above 400Nm but you have to be easy on the box. He built an engine with over 500Nm and had to detune it to around 500. The box survived, at least for the time the guy had the car. He sold it and bought an sti with the 6 speed. It’s not a box that will cop a hard life. Still, we’re not talking off road applications here
anything will slide on black ice!
True! Haha. Even my dedicated field boots go sideways on that. It would really be nice if we get newer more hardcore videos but new owners won't hoon in their brand new cars...yet. The most recent ones I can watch are those from MtnRoo, where there are plenty of newer models with CVT being taken on trails.
Yes. I think it's more of a change of lifestyle, even for previous 4EAT owners. The car will be kept as stock as possible and the fluid changes performed regularly as they tend to be much more sensitive vs the manuals and 4EAT.
I think it's a good sign though that many motor journalists tend to like the SK, considering that most of them almost got a heart attack when they heard that Subaru went with the CVT. Now they are praising the transmission and comparing it with CVTs from other makes. Cheers.
How does x mode work?? I was a bit upset when I found that the year I was getting, it wasn't offered. But I saw in some situations where it didn't seem to work any better than shutting off TC. Admittedly different situations require different systems to be on or off, but never really looked into it. Am I missing out? And can an older model have it installed?
Hearing this I'm actually happy that I got the older model before x mode was offered. Thought I was missing out till I actually tested the car
yes most cars that where tough before like VW touraeg had all kinds offroad abilitys before just couple years ago , but not anymore . it become family cars city cars , safe cars with ok traction control for road but not for offroad anymore. same with subaru sadly too. still what left there in new cars are toyotas with their true offroaders and couple other cars that with all new electronics still can do offroad like new range rovers . but again most of them getting air suspension which is good in theory but not so good when something happens or ECU go mad. even new Wrangler gone bad with too much electronic, yes it got loest gears out there and crawling like champ but then other time that you not seeing in test they have lots problems with computers going mad if you do something wrong there.
talking of simplicity VDC off or On thats all i need. still 100% VDC off on my car not half and not limited by speed. newer 2005 -2009 outback allready have just TC part off not all VDC off.
This is a good video but knowing how TV works I'm always suspicious of these. Note that the spot where he got stuck just happens to be where the cameraman is positioned...coincidence?
From what I've seen the dual XMode seems to be very good, having a second mode that allows for wheel spin without cutting engine power has been needed for sloppy conditions since VDC/TC began. They even mention pulling the TC fuses!
[MENTION=15721]scalman[/MENTION], I'm interested why you say this. Did you find the 2nd mode didn't work in slushy snow?
Fortunately I've never come across black ice myself. I would like to keep it that way :lol:
Yes I agree, this is a global trend. Offroad vehicles are becoming more reliant on electronic systems & less reliant on mechanical grip. This is fine if those programs have been designed with your conditions in mind, but if not you get stuck. There's also more to go wrong, esp in water crossings (keep Jeeps away from water lol) and in the Outback where those corrugations play havoc with anything that isn't designed super tough
