^ Thanks, Id.
I'm actually going to put it at the antenna end, behind the grill, so that I can more easily manipulate the cable. Having the cable tethered to the antenna is a right royal PITA. It makes both difficult to handle.
After joining it, I will heat shrink it to waterproof the join.
If it doesn't work properly, I guess I can always re-solder the two bits together, and wrap the joint with an extra layer of aluminium coffee can inner seal ... :lol:.
I always did my own network cabling for clients, both 10 BaseT and RJ-45 (etc). IME most network problems stem from poor handling, and the fact that most cablers were electricians. Crimped BNC connectors are tragic (IME), and most RJ-45 connections are as bad or worse ...
. Don't even think about the way most Cat5 cable has been drawn and handled!
I don't think I have ever came across a network cabler who knew what the Krone Installers Manual was, let alone had read it. A nice contact let me borrow a copy of both volumes ... :iconwink: :biggrin:. Likewise, I have never come across one who knew that Cat5 and Cat6 cables have a maximum draw force, or that this varies slightly from brand to brand. Or what the difference is between Cat5 and Cat6.
Any wonder that the network cabling they installed worked poorly, if at all?
The network cabling I have installed has never given a moment's problem. Patch leads can become damaged from use and abuse, but the fixed cables should just work.
Thinking about what one is doing while doing it usually helps ...
:rotfl:.
