Fitting the Oricom UHF300 Micro
Ratbag
Bayside, Melbourne, Vic
MY06, MY10
Forester SG & SH
5MT/DR & 4EAT Sports
Well Folks,
this afternoon after taking the trailer to Jimi for some minor additions and alterations, I decided to try to fit the Oricom UHF300 Micro CB into the row of switch blanks just below the row of switch blanks next to the fog light switch to the right of the steering column.
Scary stuff for me, as I don't like making irreversible alterations to cars, even of such a minor nature!
I took heaps of pictures, and will post them in the subsequent posts that I am reserving for the purpose, along with very detailed instructions.
I haven't got the aerial/s and Z bracket for mounting the aerial yet, but they shipped yesterday.
Ignition switched power is available from an unused plug block that is hiding behind the top row of switch blanks (black and red with yellow stripe wires, IIRC). Not yet connected to the power.
There is a ton of room for an extension speaker behind the lower dash part that the rows of switches are attached to.
Firstly, I made LOTS of measurements and trial fittings before I cut anything :eek:!
The black switch block frame is separate from the dash front, and is held on by three screws from behind.
Remove the two screws holding the bottom of the dash front to the metal framing, then gently lever the panel out of the three press fixings along the top.
Remove the fog light plug from the back of the switch.
Remove the three screws holding the switch block frame to the rear of the dash front.
It is necessary to remove a small amount of material from each side of the lower dash front opening. Detailed instructions and photos to follow.
It is also necessary the remove quite a lot of material from the lower part of the switch block mounting frame. REMEMBER that removing this material will SERIOUSLY WEAKEN the frame, and one should keep this in mind at all times when working on it. Make sure it is well supported at every stage, specially when doing the final trimming out, as the frame will now be at its weakest, and it is very easy to slip; breaking the frame, and possibly cutting oneself very badly ...
I will make a purpose-built frame to replace the one that comes with the unit to both strengthen the switch block frame, and more securely mount the radio unit.
I also intend to drill the dash front so that the unit's speaker can be heard. If this doesn't work, I will wire up an auxiliary speaker nearby.
I haven't figured out the best place to mount the microphone yet, but if it is to the dash front, I will need to make a small reinforcing plate for the back of the mounting plate, behind the dash front. Otherwise I suspect that the force required in normal use would just rip the mounting screws out of the dash front, making a hell of a mess of it.
Here's a teaser photo of the unit mounted. It is not yet connected to power or aerial, and hasn't got a proper mounting plate holding it in place. It cannot move, but it isn't satisfactory yet.
The unit isn't square in the hole yet, as the hole is still a bit rough around the edges (like me ... :lol: :lildevil:), and the standard mounting plate will not hold it square.
reserved #1
OK Folks,
Have just got time to start filling in the detail of this.
These instructions are for the series II SG Forester XS MY06. In other models and years, there will almost certainly be differences.
The MY06 XS has a switch panel to the right of the steering column in RHD cars. This has one operative switch for the fog lights, and three blanks in the upper part. The lower part is one panel that looks as if it is solely for decorative purposes. It conceals a further two switch positions that are arranged horizontally, rather than vertically. This is where I have mounted the Oricom CB unit.
The first thing is to carefully prise out one of the switch blanks. The others can then easily be removed with some help from a finger behind them. Alternatively, one can remove this panel completely by undoing the two screws at the bottom and gently levering the panel out of the clips down the door side of it. One of the retaining screws is at the bottom of the dash panel over next to the foot rest, the other is to the right of the coin bin below the switch block, directly above the bonnet release.
This is what it looks like with the switch blanks removed:
This is after the panel has been removed, and the three screws holding the frame of the switch block have been removed. Note that I have removed the coin bin. This is done by opening it, then gently pulling upwards and wriggling slightly from side to side. When re-installing, make sure that it is properly aligned before pushing it back down over the hinge that's part of the dash panel.
I have now removed the switch block frame, and trial fitted the Oricom into the hole. Note the marker pen marks on the left and right sides indicating where I have to remove some material from the dash panel itself for the unit to fit properly:
The trial fitting. I marked the places I would need to remove material from the dash panel at this stage - see the marks as above:
Note also two of the clips that hold the dash panel in place in addition to the two screws (one moulded into the dash panel on the RHS; and a white one that is detachable on the LHS near my thumb). There are a number of these, and they need to be lined up correctly when re-fitting the dash panel.
Note also that there is a heap of air space around where the unit is fitted. This should help it to remain reasonably cool in use. If it does get too hot, break into the dash vent tube, and put in a small tube to blow air over the cooling fins of the unit, maybe? IMO, this should not be necessary.
(to be continued ... )
reserved #2 - Modifying the switch block frame.
OK, this is the tricky part. The frame is quite strong in its original form. As you remove more and more material so that the Oricom unit will fit into its lower half, it gets progressively weaker, specially after the triangular bracing part has been cut.
TAKE GREAT CARE to support the frame at all times while cutting, trimming and filing. I suspect that it would be all but impossible to get another one (without buying a complete s/h dash assembly for some exorbitant price ... ). SO DON'T BREAK the flaming thing!
This is the lower switch block cover piece:
Here is the un-modified switch block frame (hereinafter referred to as "the frame", otherwise I'll never finish this bloody write-up ... :poke: :iconwink: :rotfl:):
Note the triangular bracing part:
I chose to make the first cut here, as it requires the most force to be applied, and opens up the part that will allow me to get access to the other parts that need to be cut and trimmed. I made this cut with the fine hacksaw in the next photo. Note that I have made this cut away from the edge of the frame. It is approximately the position where the top of the unit will be when mounted. I measured this position fairly carefully so that I would not have to make more cuts than necessary after the frame had been weakened (or trim).
The frame is upside down in this photo (the top when in the car is at the bottom of the photo). Note the position of the cut relative to the switch mounting 'key'.
Second cut, showing piece removed:
Photo showing the back of the frame, and where cut has removed most of the triangular bracing part of the frame:
Dremel tool with cutting wheel and sanding bit, fine hacksaw and sabre saw used for removed major bits:
It is very important not to run the Dremel tool too fast, or it just melts the plastic instead of cutting it!
After the (very) rough cuts out to the edge of the material that needs to be removed. I used the Dremel and sabre saw as appropriate for this part. Cut into the corners, then work away from the corners with material removal. If you cut towards the corners, there is a far higher risk of cutting all the way through the outside of the frame ... :(:
After the final (rough) removal of all the material, but before final trimming and smoothing with a Stanley knife and pocket knife. It is absolutely essential to support the frame at all times while doing this, as it is now much weaker. It also minimises the risk of cutting one's self with very sharp blades:
After final trimming, and with the frame test fitted to the dash panel, with the Oricom unit also test fitted:
As mentioned before, the (beige) plastic of the dash panel itself needs to have a small amount of material removed from each side and the bottom. Only around 0.5 to 0.75 mms. Really amounts to slightly more than just scraping the two sides and bottom with a pocket or Stanley knife ...
I intend to make an aluminium bracket that attaches where the Oricom bracket does to the unit, but that wraps over the edges of the frame and will drill and tap some very fine screws through this bracket into the sides of the frame. Under the unit, it may be necessary to reinforce where the triangular brace has been mostly removed.
Gidday TW, HC, NL and S2
Thanks for your kind comments everyone, and to you, TW, for being kind about what is a very rough job of fitting (so far). I hope it will look far neater once I have made a proper bracket for the unit, and moved it back about 5-7.5 mms so that my knees don't catch on the volume control when getting in and out of the car.
RB,
That is awesome, now you have me really thinking!
And after seeing it in the flesh last night? ;)
Great to finally meet in person, BTW ... :) :ebiggrin:.
Looking good, clever spot to put it :biggrin:
Just a sudden inspiration, mate. Realised that the strip under the switch blanks wasn't just there for aesthetic reasons, and voilà :poke: :biggrin: :cool:.
Great job so far Ratbag... very curious about where the rest of it is going!
There is a LOT of room behind that particular panel, S2. I plan to drill some holes for the speaker noise to escape through, and if that doesn't work well enough, I will panel mount an external speaker behind the dash front behind the ignition keys - that's all just empty space ... .
The Mic is a bit more complicated ...
I have a few spots in mind. When I settle on a spot, I will make up an aluminium backing plate to reinforce it, and put small bolts and nuts through the dash panel to secure the fascia plate and holder through the dash panel and the reinforcing plate behind it.
Such an item can/is subjected to surprising amounts of force in normal use; and if one mishandles it by accident, it could easily just rip a chunk out of the dash panel, screws and all - so just fixing it with the supplied self-tappers is out of the question; and even using bolts, there will have to be a load distribution plate at the back of it.
What with the cats having to stay at the Vet today for blood/urine tests; having to pick up the trailer from Jimi possibly this afternoon; and a function on late afternoon and evening; the chances of my getting any more piccies uploaded today are minimal. I want to write up each step as I do, which all takes a lot of time.
The bare photos are here for those who can't wait :poke: :iconwink: :biggrin: :lol: :
Fitting the Oricom UHF300 Micro photos
[EDIT] To see these images, you have to login as U/N = ors_guest and P/W = Subies. Both are case sensitive. Then click on the link and navigate to the relevant sub-album. [end edit]
Please note that the album is sorted from oldest to newest, rather than the default of most recent first ... ;).
I will follow this up with instructions for installing the aerial and power supply when the aerials arrive ...
If your looking for something to cover the ugly cuts in dash work. A sharp knife, black irrigation dipper hose and a hairdryer/heat gun to straighten it out is great for making a nice edge to cover cuts in the dash. Little gasket silicon inside the tubing holds it in place as well.
Gidday Id
It isn't nearly as crooked as it looks in that photo, mate, but thanks for the tips, anyway.
Phone cameras at close range aren't known for lacking serious barrel distortion :eek:, and mine is definitely not an exception to that rule!
Once I have made a proper bracket for the unit, all that will be needed is a final sand with some wet & dry paper around the beige part where it's still a bit rough. Other than that, it looks as if it was supplied as part of the car :ebiggrin: :biggrin:, even if I say so myself :lol:! Haven't got to any of that stuff yet, as it all has to come out again to make and fit the bracket, fit the aerial feed and connect the power ...
Looks great so far Ratbag :)
Can't wait to see it once it's finished in full :raz:
^ Thanks Mr T..
Aerials arrived by Aussie Post courier late yesterday.
Now the hard part begins!
From my Batphone
It is great that you are doing this. Your car is the prototype :lildevil: You make all the mistakes and we learn from it :lol:
Seriously this is going to look like a professional job when done.
Absolutely.
I will pull my lower panel out on the week end, and see how the switch panel is fitted. As mine has two switches in use hopefully it is the same as in your car which is a later generation.
Thanks, HC.
The next challenge is to fabricate a special "Z" bracket for the aerial, as the beautifully made, stainless steel one I spent $15 on just won't fit, not anywhere ... :(.
The "Z" bracket I have bought is also too short vertically. Using it will put too much stress on the cable IMO. But I can use it as a template, so it is of some use.
What I'm considering is making a bracket to bolt on using the rear bonnet hinge on the bonnet side of the hinge. This will mean that the aerial will lift with the bonnet.
This could be a little inconvenient when the 6.5 dB whip is fitted, but mostly I plan to have the 3.0 dB stubby in use.
It will also be closer than it could be to the front P/S door pillar. However, eye-balling this, when the aerial is vertical, it is actually outside the line of the side of the main body of the car, so shouldn't effect the signal too badly. I have just measured this, and the base of the aerial will be around 700 mm from the nearest part of the P/S door pillar. The tip will be further away. When the whip is being used, it will be well above the roof line, and most of the aerial will be around 1m from any body metal.
I have considered making a base plate to which I can attach the SS "Z" plate, but I think that doing this would make the bracket weaker, not stronger.
Maybe tomorrow I will make up a rough trial version out of some scrap to get the dimensions and shape right before I make the final version out of 2-2.5 mm aluminium sheet. My bonnet is aluminium, so that's not a problem. I will get a can of touch up paint and paint the bracket the same colour as the car.
I have also considered using one of the tailgate hinge bolts, but this will make it very easy to damage the aerial, even with the stubby 3.0 dB fitted. FAR too easy, IMO.
I know what you mean by the little z bracket, i had mine on one for a while, it bent too easily and vibrated enough to take the paint on the bonet back to bare metal. I drilled out the top of the bonnet hinge where there was a trim plug and put the aerial there
Gidday Id
I could see that this would happen, and had already thought of ways of isolating the bottom mounting point from the body. I also planned to use the two screw holes in the plate to stabilise it further - much as I hate drilling holes in cars!
At that point, I started looking at the alternatives ... :poke:
Have just woken up properly (SWMBO had an early start today, and this always buggers up my sleep!), so will look at it when I have got under way ... :iconwink:
How do you intend to handle the heat dissipation? These little radios get VERY hot. Mine mounts in the center console between the driver and passenger seat, with plenty of air flow, and even so, after a day of outback driving, it's way too hot to touch. And that's just receiving; spend some time transmitting, and the heat sink gets hot enough to sizzle spit.
