Interesting discussion guys.
I was, and still am very concerned about using snatch recoveries on my SH Forester because it doesn't have rated recovery points. On the rear I am happy to use the tow hitch receiver with a rated pin but at the front, it's a different story. The tie down loops are just that and the tow ring that screws into the front bumper is for towing. Even though the driver's handbook uses the term 'recovery" I was not convinced so I wrote to Subaru and asked them exactly how these points should be used.
Good work Beachworm, glad someone decided to find out once & for all.
I'm a newbie to this site & haven't bought my chosen Forester SH yet. Currently have a troopy & some experience in recovery so be nice to me.
Now have I misread this below or am I just crazy??
Subaru replied saying that all three points are suitable for recovery from mud and sand using towing as a recovery method. They do not, under any circumstances, recommend that a snatch recovery be attempted using these attachments.
Isn't this is totally contradictory & confusing for the inexperienced? I guess what they mean is "all three points are suitable for TOWING out of 1" deep mud or hard sand." There is no delineation between being "stuck in deep mud/sand" & being towed along in shallow mud/sand.
I guess the official description of "recovery" in the traditional motor industry, which would date back from since the Model T, is to be towed along a dirt/bitumen road & maybe pulled out of a ditch or towed along a small amount of mud/sand near a road. Eg. you drove the car off the road accidentally. It doesn't mean the more recent trend of popular 4WDing where one may be neck deep in quicksand. Eg. you intentionally drove into a mud hole to test your vehicles prowess, in soft sand miles from a road or stuck behind a small boulder in a river crossing.
Recovery in the "traditional on road motor industry" means being in the situation in the first part of the above paragraph not the second part.
Recovery in the "4WD/AWD motor industry" means a completely different thing.
You could be stuck in a mud hole with you wheels jammed behind a reverse sloping rock & "recovery" means snapping your 5000lb snatch strap & then thinking "why did that break"? Is it too old/worn or is there something else unforeseen jamming my car in? Should I try to recover it backwards? Ok, hopefully you are with several mates/cars & they have more snatch straps. You really want to be snapping your strap rather than your vehicle.
I'm learning a lot from this website. I did a 4W Driving & Recovery course with the Toyota Landcruiser Club & there was no real concern with bending your frame etc. I guess the straps would snap first.[/QUOTE]
I have purchased a distribution hitch to allow both tie-down hooks to be used in an emergency but I would try everything else first.
What do you mean by "try everything first?" What other options are there apart from digging/Maxtrax?
I had a look at the tow points on a SH & they are tucked quite high up in the front. It would cause damage to the bumper just towing let alone a snatch recovery. Can one jam a couple of 4x2 timber blocks up above a tightened equaliser strap? Or how else do you avoid damage?
So are these towing hooks not bolted/welded onto the chassis like where you would attack a bull bar? Guess I'll find out when I buy it.
What about the screwing towing eyebolt? Isn't that screwed into a solid part of the chassis? Is there on on either side or just on the drivers side light on the XV?
