MiddleAgeSubie
- Dec 15, 2013
- 990
- AZ
- 2018 / 2008
- 4Runner / Tribeca
- 5EAT
I guess what I wonder is how are exhaust jacks easy to use. I put it in the area where I would use a normal jack, leaving what I thought was enough room. But, it got into the wheel well. Then I put it a lot more towards the middle of the car, all in an attempt to simulate tire replacement. Now part of it got out and wanted to hug the door. Then I pushed it further under the vehicle, but now the further edge was not far from the exhaust and there was some plastic I was afraid would get crushed.
Then I positioned it here and there without trying to inflate it again. It gets either under things with protruding bolts (skid plates) or the almost inescapable exhaust, or under the plastic that is found elsewhere.
I imagine that in case of real trouble I will find a way to make it work, but "EASY" is the last adjective I would use to describe my failed attempts to make any use of it at home.
Now, I used air compressor, not exhaust gas, which slowed me down, but that is not what I am referring to as "not easy." Rather, I mean the positioning of the thing under the car.
Where exactly under the car do you put it if you want to replace a front or a rear tire or to get either the front or the rear unstuck? The exhaust is in the middle of everything and I have dual exhaust to boot.
