- Dec 17, 2008
- 209
- Huon Valley Tasmania
- 2007
- Forester
- Manual
Thanks lads.
Havachat, I'm coming around to thinking (subject to proof next week) that the trick is to do EITHER:
Standard front springs and lift blocks (which is what I'll have)
OR:
HD springs without lift blocks (which is apparently what you have).
Both together, as you can see from the picture of my car above, gives too much lift at front, throws the suspension geometry out and (as I have discovered) the car drives like a drunk pig on skates unless you add more bits in to adjust (as NachaLuva suggests).
At the back, it's different, certainly if (like me) you carry a fair bit of weight around. I'm happy that the 1 inch block plus the raised HD Kings springs are a good answer for me.
As for shockers, I was perfectly happy with the OEM shockers when I had the OEM springs. But I like them a lot less now. I am thinking that you need to have harder shockers if you have harder springs, otherwise it floats and wallows like ... er ... like a drunk pig in mud. And I reckon I'd be happy with harder shockers if I still had the OEM springs - soft spring, taught shock valving is OK. Hard spring, sloppy shock valving is (as I have discovered) not good. I am anticipating tha the softer front springs will be a much better match for the standard-rate shocks and I'll be back to something similar to the way the car behaved ex-factory, which was fine. (But higher, of course.)
OR:
