NachaLuva
Product Developer
The center differential in a first gen manual forester is essentially 'open' when there is only a low speed difference between the front and rear wheels. That is why you can jack up one wheel and let the the clutch out with the engine at idle in 1st gear low without the car going anywhere. Its only when you accelerate a little that the centre diff start to change the 50:50 torque split to a ratio with higher torque sent to the end of the car with both wheels on the ground that forward movement is actually obtained.
I'll have to check this but you may have a shot centre diff.
NOTE: to all those who didnt realise with an AWD that uses a vLSD centre, its critical to have the same size & type tyres front & rear, even having different brands can bugger the centre diff. Also, using the handbrake while moving will also destroy the centre diff. Handbrake turns are fun but very costly in a Subaru!
I am no engineer and I lack any actual knowledge of how 4wd and AWD systems operate. However, from what I read I have to conclude that the only way to get what you want is a true locker.
There are 4 types of front & rear diff:
*open: useless offroad
*vLSD: better than open but very limited (pardon the pun
*pLSD: plated diffs incl Subaru OEM from WRX STi, not sure about other STi's, eg Forester STi or Liberty STi. Also aftermarket like KAAZ & Cusco. Subaru pLSD is very useful at keeping forward movement with a lifted wheel, I can vouch for this. Cusco & KAAZ are even better. Slip between the axles is be varied depending on type & setup
*Locker: there are many types of locker but they all "lock" one axle to the other 100%...ie, no slip
