NachaLuva
Product Developer
Despite the calculations I know from the yarra glen/healesville? trip we did with Nachaluva, Barry, RB and Matt that the 1.19 fell over on one of the steep climbs that both Nacha and Matt did with ease. On another they were able to cruise up when for the 1.19 it was a matter of going much faster than was really desirable to over come the gearing issue. I saw the same with BCOutback and his 2.5 and 1.19LR in Wyperfeld in the sand. Stopped dead in the sand when everyone else could get moving from a stop. Nacha's foz also did better than my H6 single range in the sand when it came to low speeds. I know that a lower speed is very much desirable for some of the more gnarly obstacles we come accross occasionally.
In these circumstances the exta .4 low range exceeds the exta power torque of the bigger motor.
Just a question of what sort of offroading you do. But i seriously do not consider any 1.19 car comparable to a 1.59 L series for ability to crawl over obstacles or the degree of gradient they are able to climb. If i had to recommend to someone an improvement over the comfort of an L series while keeping it in the Subaru famility and maintaining as much of the L series offroad ability as possible, i would have to suggest the 1.49 cars.
Exactly!
There was also the creek bank that I crawled up in Wyperfeld NP. With a 1.19LR, the only way to make it up would have been with more speed, but then you would bottom out at the start and launch at the top. Makes for spectacular photos but not so good for the longevity of your beloved Subie.
Also, remember Walhalla? I was able to make it up (just lol) a VERY long steep climb in 1st LR that Venom with his H6 was unable to with his single range GB.
Gearing is everything!
It depends what you mean by "articulation". My 1968 LC deep well ute had all the torsional rigidity of a piece of wet spaghetti. The only way to lift a wheel was to either crash the truck, or to jack a wheel up ...
Modern vehicles have far greater torsional rigidity than (most) older vehicles. This allows the designers/engineers to ensure that the wheels and suspension do precisely what they are designed to do, and not go off on a fantasy frolic of their own (e.g. 1960s Chrysler Valiants ... ).
It is these features that make the car stable on the road, with highly predictable handling characteristics so lacking in most vehicles from my youth.
Its not torsional rigidity thats the issue, its wheel travel or articulation that is the downfall of Subies
Again, it all depends on what you want to use it for.
Personally, I find the 1:1.196 LR to be a good compromise. Would I like it to be about 1:1.250? Yes. Do I want it to be as low as 1:1.4xx? No.
The utility of the 1:1.196 is to be found in that the car can be driven in LR all day without damaging anything.
But why would you want to do that? It prematurely wears out not just the LR gears but also all the other gears as in a Subie the LR is BEFORE the gears. And with your greater torque, there's no need.
LR isnt for cruising around...its for extending 1st gear and sometimes adding a gear between 1stH & 2ndH.
