scalman
- Dec 1, 2017
- 2,565
- Lithuania
- 2006
- 2006 3.0R 5EAT Sportshift VDC/VTD LPG
- 5eat Sportshift
cars101 gives this info about VDC outback models
maybe foresters have diff specs, but outbacks if believe this info all VDC models using VTD.
but anyways my model is not listed anywere oficialy. 2.5 4eat with VDC is hard to find.
anyway using VDC as i call it helps me alot. in winter using VDC on snow its great, in mud turning VDC of and still have great split for better traction. on slow speed situations VDC helps to finds traction going slowly. active AWD needs momentum in most cases to go same places.
VDC All Wheel Drive VTD All Wheel Drive, VDC variable dynamic control model only
VDC: (variable dynamics control)
The overall name of the system, and of the model, of full time traction control that senses vehicle direction and uses brakes, throttle and engine management to control and maintain stabilty.
VTD (variable torque distribution) All Wheel Drive system that transfers powers front to back. Usually 45/55 front to back split.
The way the system operates
the VDC Outback is always in all wheel drive, using a Variable Torque Distribution (VTD) of 45/55 front-to-back power split. When there is slipping the VTD system will vary and adjust that front to back 45/55 power split.
When the wheels are spinning or the vehicle is not going in the direction it is being steered, the VDC (variable dynamic control) engine management system kicks in and will use brakes to slow down wheel spin and control vehicle direction, and also control engine output to cut back power to the wheel or wheels that do not have traction, again to reduce wheel spin and re-direct the vehicle in the direction it is being steered.
