Th stiffest 14" Eibach barrel springs I can find advertised is 4.5Kg/mm, this has a stroke of 244mm. The 12" come in 5.8Kg/mm and 6.3Kg/mm, this has a stroke of 205mm. Do you have a link to the springs you are looking at?
On my SG, while stationary on level ground, the springs support 365Kg on each front corner and 325Kg on each rear corner. An Sf will probably be a bit lighter, especially on front, but depends on mods ect.
While the car is sitting stationary, 6Kg/mm springs on front will compress 365/6=60mm. This is about 30% of your shock travel, I think rally you want about 1/3 for rally, so you're about right. If your car is much lighter then my SG maybe consider 1 step lighter rate. Low speed 4wding you want the car to sit closer to 50% of shock travel, hence softer springs. Keep in mind if your car is sitting at 30% shock stroke it will be higher then 2" lift. If you wind down the preload adjustment to lower car, the springs won't extend to full shock adjustment and you will need helper springs to maintain preload. The part of the stroke where the helper springs extend is wasted stroke IMO as they take negligible load.
4.5Kg/mm springs on rear will compress 325/4.5=72mm. Which is also about 30% of shock stroke. So about right again.
So springs are about right for what most people like for rally. Providing there are ones long enough in those rate.
I briefly drove my car with 55Kg and 45Kg springs and personally I thought they were good on tarmac, but destroyed grip as soon as the gravel road got rough. But I'm not a rally driver and wasn't on rally roads, just corrugations.
