I have an SF, and 220-230mm is maximum stroke for the front if everything else is stock, especially the inner CV axles.
Now if you want more stroke at the front of an SF, go for SG A-arms and SVX axles. This new combination can give a gain of another 10mm of stroke (250mm) and 20mm more droop because the housings have to be longer, I actually have 370mm front housings but would need 380mm housings for more stroke...but its going to stay as it is !
I don't think you can get 300mm usable stroke at the rear, that would be 325mm shafts as the top hats "eat" 25mm of the stroke. I haven't tried it but from what I experienced, the CV axles won't go that far of an angle. If you want that much stroke, you have to install a 1" subframe lift. The same can be done to the front too ! See Jeremiah's kit.
