Macksterminator
- Oct 26, 2016
- 2
- Big Island Hawaii
- 99/00
- Forester
- Auto/manual
Hmmm…
I have no body lift. But I have 1" trailing arm spacers and SG lateral links for a wider rear track (+3cm) to keep the springs from rubbing the frame at full droop.
I too have a custom length of the DT2 version but a DT1 version is enough for the use.
Rear SG top mounts are easier to modify for the springs to sit nicely (ID 60mm or 2")
gotcha, its Jeremiah thats running sub frame spacers not you and not a bodylift my mistake.
I have a few more questions if you dont mind, sorry if they seem stupid but how else a fool gonna learn!?
1. Both you and Jeremiah have custom length DT2's. Is it the extended length that gives you more wheel travel or will a set of DT2's straight from the factory give more wheel travel vs stock suspension.
2. this strut setup will give ~2" lift?(as you replied to Teni)
3. You mention modifications to the top mounts(i assume you are referring to strut mounts), is that because you have a extended length or thats just necessary to install the DT2's. Either way what sort of modification is made to the top mounts?
4. I see that you said that you have the exact same set as the pic that roosmsg posted, are you then running the springs that came with the struts as opposed to Jeremiah who got longer struts and had to go with the swift barrel springs.
Again i apologize if my questions are ridiculous or repetitive but i am very excited to learn and both of your suspensions make me drool allover my key board
