Barry
Someone had to say it...
Frogstar,
There is nothing wrong with a Lead Zeppelin!
Frogstar,
Front .299"
Rear .516"
These dimensions were only calculated, never tried or tested, but should be ballpark to what you would need to get the camber close. You will most likely need camber adjustment bolts as well.
I know Frogstar said a 7mm/.275" would have been better but you are at 2x the offset on the rear (.516"/13.106mm)...thats why I asked. Thanks for the reply. :biggrin:
G'day
Looks like a lot of work went into this
Would this fit a 1998 forester? cause thats what im looking at buying and already looking for a way to lift it :ebiggrin:
Howdy and Dimitri!!!
Look back through the thread and pay close attention to frogstar7055's posts, he built his lift for an SF series Forester as well. Make sure you verify bolt hole spacing before drilling anything.
Sure you can! Weld it back up, grind it flat, drill again.yeah, i reckon.
you cant un drill something
Thanks for that
