Ratbag
Bayside, Melbourne, Vic
MY06, MY10
Forester SG & SH
5MT/DR & 4EAT Sports
A basic rule is that if you are not sure what you are supposed to do: DON'T DO IT!!
This sort of thing should always be learned from those who do know what they are doing.
People happily talk about snatching another vehicle. Mostly they understand what they are doing, or have been doing it so often and for so long that it is second nature to them.
Snatching (and towing ... two very different things) can be extremely dangerous if you do not understand the safety precautions needed. When I say "dangerous", I mean that people can easily get killed; and have been.
Some other "rules" or guidelines that are worth knowing:
1) It is generally advisable to avoid snatching a vehicle that is much heavier than one's own. It can literally pull your vehicle out of shape if not done with great care.
2) If you MUST do #1, then always use shackles rated for the heavier vehicle's weight, while using a snatch or tow strap rated for the lighter vehicle's weight. Using a heavier vehicle's recovery straps may well deform the entire frame of the lighter car.
3) Recovery equipment that you buy should be rated - i.e. have stamped or marked on all components what its maximum load limit is.
These ratings come in two different classes.
"SWL" (Safe Working Load) means that the component is capable of being subjected to the marked load in a dead lift situation (i.e. lifting vertically off the ground).
"WLL" (Working Load Limit) means that the component is rated for the marked capacity as long as the load is rolling - i.e. much of the mass of the vehicle or load is being carried by its contact with the ground.
Items that have a WLL rating will usually have their Breaking Strain ["BS"] listed. By engineering convention, the BS is about double the WLL, and the SWL is normally 2/3 rds of the WLL; but these relationships can vary. I would be profoundly worried by (say) a load distribution strap that listed WLL = 4,000 kgs; BS = 5,000 kgs. My own LDS has a SWL of 4,000 kgs and a BS of 8,000 kgs.
Almost always, the "SWL" figure will be considerably less than the "WLL" figure when both are marked on a component. e.g. the "WLL" rating for my creeper winch is 2,400 kgs, and its "SWL" rating is 1,600 kgs.
4) A snatch strap should be rated at approximately double the weight of your vehicle. e.g. my snatch strap for my Forester is rated at a BS of 5,000 kgs. The bow shackles I have are rated at a WLL of 3,200 kgs.
One should never use a snatch strap for towing; or a tow strap for snatching. A tow strap has almost zero stretch in it. A snatch strap is designed to stretch (quite a lot ... ).
5) One should use a rated load distribution strap between the tie down points on Subarus that do not have a dedicated recovery point and recovery eye bolt.
When using a load distribution strap, the rated shackle should be attached to one vehicle tie down point with a rated bow shackle; the other end of the load distribution strap is then passed through the eye on the SNATCH strap; then the eye on the load distribution strap is attached to the other tie down point with the other rated bow shackle. IOW, one should never attempt to tie off the load distribution strap other than to the rated shackles attached to the vehicle tie down points.
UNDER NO CIRCUMSTANCES should the load distribution strap be attached to the snatch strap by any other method - e.g. by using a bow shackle; this latter would be a deadly mistake.
When using a recovery eye bolt on later Subarus, one must follow the instructions about fully screwing the bolt into the body thread, and tightening it according to the instructions in the Owner's Manual.
6) When winching using a tree as an anchor, one must use a tree trunk protector. This is a non-stretching rated strap with padding that must again have its two end eyelets joined by a rated shackle, or more commonly by the winch anchoring hook.
7) NEVER, NEVER use a tow ball as any kind of attachment point - NOT EVER. It is OK to use a rated bolt or shackle through the tow ball bolt hole in a removable tow tongue, or preferably to use a rated snatch strap attached using a rated bolt through the main tow bar frame in place of the tow tongue. The tow tongue retaining bolt is fine for the purpose, but ENSURE that the retaining split pin is securely in place.
8) A snatch strap should always be used with a 'dampener'. This can be a purpose built sand bag type thing, or something as simple as a blanket thrown over the middle of the strap before any load is put on it. Such a thing can absorb much of the energy if anything breaks ...
9) DO NOT ALLOW any person to stand within the maximum (stretched) length of the snatch or tow strap on either side - i.e. if the strap has an un-stretched length of 8 metres, onlookers should be a minimum of 16 metres away in all directions. This distance includes to the front and rear of the vehicles involved, and on all sides [Thanks, Mr T]. If the strap breaks, it will be like a guillotine. There is enormous energy stored in such a strap when under load. Specially if a shackle or bolt breaks and is still attached to the whipping end of the strap.
Keep the bloody spectators and children well out of harm's way ...
By now, you should be able to see why I said that one should learn this stuff practically from an experienced, careful and knowledgeable person. It is a big part of the value of forums like the ORS in that one can meet up with just such people and learn from them, both in the field and on-line.
[EDITS] fixed up the confused and wrong description of use of a load distribution strap, and clarified a few other points.
And fixed a couple more bits ...
[end edit]
Very good points there Ratbag & very well written. Well done mate :raz:
Like you said keep bystanders well away for the recovery for their safety.
As a rule of thumb, if you are a spectator or not involved & just watching, you should be a minimum, a minimum of 2x the distance of the recovery distance away.
IE: If using a 8mtr snatch strap you should & need to be at least 16mts away from both the vehicles involved.
Another thing to remember, is that all snatch straps have a limited life span aswell. They don't last forever :iconwink:
Thanks, Mr T.
I just realised that I made a flaming dog's breakfast of the description of how to use the load distribution strap :puke:
After posting this, I will edit my original post so that it isn't both confusing and WRONG!!
I will also copy your clear instructions to looken-peepers, if you don't mind. I'm sure you won't, as you are at least as committed to safety in all aspects of our driving as I am. Thanks for that clarification - it adds to what I have already written.
No worries mate :)
Go for it :raz:
^ Thanks, Mr T.
Please check out my altered post and see if you can spot any other bad mistakes I've made :rolleyes: :shake: :redface:.
are these things tow points or tie downs? on the front & rear corners of almost all cars
my broken car has been pulled out of deep mud(more than once) with these, lots of others do the exact same thing
race cars are required to have them
Hey Brad, its Matt from that post on FB :biggrin:
You know what I've been saying about the dangers of using tie down points for towing & esp for snatching, so I won't say any more just yet. I'll let others have a say....
lol bringing the posts here now :)
After reading through your post RB, I just went outside and mocked up the setup so that people have the pics to easier understand, hope they help!!
Here I have my distribution strap, with WLL 3 1/4T shackles I believe, as the 4 3/4T shackles are a bit big.
Here is my tow strap fed through the distribution strap.
And here is my carry! Every strap is rated between 8T and 12T
Everyday carry is-
1x TJM Towstrap
1x ARB Treetrunk protector(exactly the same as a distribution strap)
4x WLL 3 1/4T shackles
2x WLL 4 3/4T shackles
Gloves and Fluro Vest
Dampener
For when I go offroading I add-
A second distribution strap
Snatch Strap
Drag chain for pulling fallen trees etc
Bradze, what happened on that occasion, on the pic above?
Gidday Brad
That's a rated recovery bolt, mate. You have one on the back as well. Our SH has them, our series II SG hasn't. With the SG, I have to use the tie down points (see AU's post). See my OP regarding built in recovery points.
Gidday Au
That one's right.
Your photo is right. Your description is wrong - it should read "Here is my distribution strap fed through the eye of the snatch strap". As I discovered originally, writing these things precisely is bloody hard!
Thanks for your photos. They make things a lot clearer.
A tree protection strap ought to be either softer and/or have more padding than a load distribution strap.
Yeah they do have more padding, which stops the shackles clunking around as much on the points. Yes yes, the wording is extremely confusing! Why I decided to post these images to help!
I think there needs to be a ORS handbook! With specific info for recovering subarus, offroading subarus, specific subaru mod info(such as the 50/50 auto dif lock, fan cut off, extended diff breathers, snorkel), subaru field repair tips(such as pulling fuses to this and that, how to limp home when "" breaks), UHF tips etc.
^ Yeah, doesn't it ...
Every thread I visit, I review the tags (usually none) and add whatever I think fits the model you are describing.
Thanks, Au.
Any forum is only made stronger and better by the active and positive participation of its members ... :) :biggrin: :cool:.
RB, what is the tow point rated to?
Please note, there is a difference between a recovery point found on 4WDs and tow points or tie down points, which is what that is
^ NL, it's described as a recovery point in the OM ... :poke: :iconwink:.
Have you ever seen and held one of these bolts in your hands? They are a LOT bigger and stronger than they look when attached to a vehicle ... The thread is large in diameter, and has a very fine pitch.
Even generalising from the tie-down points on an SF to those on an SG is a pointless exercise. The SG has both stronger tie-down points and a lot stronger front sub-frame structure.
Even the OEM tow bar on my SG is rated at 1,800 Kgs, with a ball weight of 180 Kgs - both figures are far in excess of what the vehicle is legally allowed to tow (1,400 Kgs braked), or the legally allowable ball weight (75 Kgs).
As far as I know it is unrated, though I believe RB in a thread a while back you came to the estimation that it would be in the ballpark of 5000kg swl
^ Being built in to the vehicle by the OEM, and presumably fit for purpose, it doesn't have to be rated as such.
It's a bloody heft bolt though, and made out of beautiful, heavy material.
Don't ever lose one. I can imagine what dear old FHI charge for a replacement ... :(.
Almostunseen,
I am no fan of the bull bar's looks, but I LOVE the bumper replacement portion of it! Looks like a key upgrade, especially for an Outback. I wish it did not cost that much (not to mention that shipping would probably be prohibitive).
What gain in approach angle and front bumper clearance did it provide in your case?
I cannot believe how great, from a functional perspective, your car looks from the front--especially with those tires!
It does not seem that anyone in the US offers anything similar. Crude off-road bumpers are a different story, but this is a functional+elegant solution (minus the hideous upper portion, anyway;)).
