^ Yeah, that's also what I attribute it to, Mr T.
I don't know why manufacturers are doing this. Marketing, perhaps?
If it weren't for the expense, I would probably go "backwards" to 15" rims with higher profile tyres on the SG. Not worried about the width. Even a 205/75 15" is still legal, and would give far better ride comfort with little to no sacrifice in handling.
[EDIT] THIS IS WRONG!! MAXIMUM INCREASE IN TYRE SIZE IS 15 MM - Thanks, Pedro ---- Still legal (24.1 mm bigger diameter, so less than the 25 mm allowable), and would correct the speedo error in my SG. Insurance company is not bothered by tyres being slightly narrower (more resistant to aquaplaning ... ). Even a 215/70 15" is legal. [END EDIT]
Don't know if there were any OEM alloys made in this size though. Going from steel to alloy has a dramatic positive effect on handling and ride, and going from alloys to steel has the opposite effect ...
We could always swap the SG 215/60 16" alloys onto the SH. Probably improve its ride markedly ... Sell the OEM 17" alloys off the SH.
The SH has a longer wheelbase, and more rear passenger room than the SG. It's a bigger, heavier car all round. While the SH might not seem to be much bigger in dimensions, when you multiply it all out, it has a considerably greater volume than an SG. OTOH, while the SG is a bit longer than an SF, it is very similar in size. It should be
more comfortable than my SG ...
We both have sheepskin seat covers in the front. That makes a huge difference IMNSHO. Sheepskin removes the high frequency vibrations that is present in all cars very effectively. Even the crappy stuff that one gets in off the shelf covers does this.
My point about the rim/tyre size difference is that it doesn't take much to effect the handling on such finely balanced cars. Remember when I had my new tyres fitted on Roo2 and the frame/four wheel alignment was done?
The frame was straight, and each of the wheels was within spec for alignment. However, each wheel was pointing in a different direction from the others. None of them were symmetrical.
This made it handle like a canal barge. A bit similar to what Tannin is describing. Floating in the lane at <80 kmh. Pulling to the P/S in the last couple of metres when stopping. Vagueness in the steering. Originally, increasing the tyre pressures in the P7s from spec to 35 psi helped a bit. After the alignment and new tyres, the car was suddenly completely different to drive. As Tannin says "handles the way I expect a Subaru to handle", or similar.
As I have said previously, I drove my '68 LC around for about 18 months or so with the front wheels about 1 1/8th inches out of alignment. Had no perceptible effect on the handling, braking or tyre wear!
Not so with our Subies ... But then, they don't handle like a badly loaded truck to start with!
