Are they grippy or not?--------------------------------[/B]'Stick like poop to a bl@nket' - to quote a traditional Aus saying.
All else being equal, the longer they last, the less grip they have
The addition of silica to tyre compounds is a game changer. For a similar tyre type and use on my motorbike it added well over 50% to the life.
AFAIK the only AT tyre in suby sizes to have it is the Geolandar AT-S.
Indeed- which is why I said all else being equal
i would say from this research some on this forum would be running an illegal size
Im pretty tired (pun?) but I got from that 15mm is allowable without certification. Does that mean 15mm+ could be approved with an engineers certificate?
I, ahemm, may or may not be one of those members.
Hope you all are a bit more certain about what the limits are going up in size.
i went for stock size because i am too tight to buy another set snow chains :lol:
Got my new set AT/S, running smoother and instant 5mm lift :rotfl:
Wahoo for extra tread.
As for being too tight to buy new snow chains, they are just as effective in the mud, use to use em on an old late 70's Honda accord to get down to some out the way surf beaches in NZ years ago, always fun to see hard core 4WD hilux wagons with muddies on looking at you sideways when coming up a muddy track
Would recommend a pair to all those in the states less well endowed with snow
FYI I had to cough up $225 AU for each geolandar AT/S, stock size.
Expect to get 75,000km out of this set too, albeit was on the wear indicators on the set that just came off with 76,500km on them.
$225 good price i got mine cost price through a work shop for 218.
what size bfg are you going taza?
im hoping to get 60,000 out of my geolanders up to 5,000
$225 was through Gob Jane T Mart
Was just under 3 years ago I got the other set, have been diligent in checking pressure and rotating.
Always would run them up to 38psi when loaded for long highway runs on the blacktop.
Keep in mind when going for longer life tyres, the tyres are subject to aging even if not being used, the rubber does go brittle over time and side walls weaken, hence the general rule of thumb I have often heard quoted, is to plan for max life of 5 years, have to say it seems real when I look at how dodgy the tyres on my trailer are now with lots of tread left and 8 years under them, but only 5,000 to 10,000km done.
How much are a set of BFG's going for?
I got 45,000km from my Geo AT-S which are 215/70r15. Stock size being 205/70r15. My new bfg's will be 215/75r15.
Just over $300 each. My geos were 225$ each before. I need 5 too so that's $1500![]()
