Thanks guys, pretty happy with it. Still have some sorting out to do. Not very happy with the original kit:
*All bolts non-zinc plated - guaranteed to rust & seize
*Wrong size bolts
*Wrong size split washer
*Missing bolts
*Missing nuts
*Bolts on strut top welded in at an angle! Had to file strut tower to make them fit
*Crush tubes too short so blocks have crushed slightly on fitting
*Kit incomplete: no blocks for moustache bar supports, also heat shield or radiator hose extension
*Poor advice on fitting
General quality of the kit was poor, similar to the sumpguard I got from the same place:
*Weld lifted on the bend join (no penetration)
*Front mounting hole in wrong position
*Front lip not wide enough so when I filed out the hole it came out the side
*Poor design: the front lip acts as a scoop, result is it bends out making it a worse scoop
I also got a replacement steering extension from him...he charged me $20 for postage yet it only cost him $6.
Where's the negative feedback button!
