Air Conditioning Tips
Another thing, if your aircon doesnt seem to work so well when you are at lights or stopped and works well on the highway it would pay to check the thermo fans :iconwink:
My aircon was blowing warm/cold/warm/cold but never actually getting cold enough. Found it was a worn AC clutch plate not fully engaging. But instead of buying a whole new Zexel compressor like the dealer said was the only way, I adjusted the clutch clearance by removing one of the 3 spacer shims on the clutch shaft and all was good to go.
Excellent step by step here and takes an easy hour to do without removing any major components!
https://www.subaruforester.org/vbulletin/f87/how-adjust-c-compressor-clutch-116835/
AC deodorising.
Wurth worked well on my subie for starters until I replaced the cabin filter.
PRODUCT NAME
0893 764 100 - WURTH AIR CONDITIONING & DISINFECTION SPRAY
SYNONYMS
"Heating Spray", "Manufacturer's Code: 0893 764 100"
PROPER SHIPPING NAME
AEROSOLS
PRODUCT USE
» Application is by spray atomisation from a hand held aerosol pack.
Used to disinfect refrigerated air conditioner systems.
SUPPLIER
Company: Wurth Pty Ltd
Address:
4 Redwood Drive (abn 48 002 487 096)
Dingley
VIC, 3172
AUS
Telephone: +61 3 9552 9552
Telephone: 1800 331 603
Emergency Tel: 1300 657 765
Fax: +61 3 9551 2994
n- propanol 71-23-8 30-50 ethanol 64-17-5 10-30 benzyl C8- 18 alkyldimethylammonium chloride 63449-41-2 <0.1^ glyoxal 107-22-2 <0.05^ water 7732-18-5 NotSpec non- flammable propellant
NotSpec
Code:
https://www.wurth.com.au/msds/0893_764_100.htm
Cheap SG OEM cabin filter replacement in Aust:
Sakura Cabin Air Filter CA-18220
https://www.onlineautomotive.com.au/Sukura-Filters/Sakura-Cabin-Air-Filter-CA-18220
$18 AUD
Got my radiator re-tanked and the dude left out the foam liners between the evaporator and radiator. This means when stopped and the fans blow air does not get forced sucked through the evaporator making it less cold. Check you foam separators first, if missing then that's your problem.
https://static.opposedforces.com/epc_img/583494973004.png
Part numbers:
Code:
4      Packing-condenser            73237SA010
6      Packing-condenser            73237SA000
12     Packing-condenser            73237SA020
^ I'd say they would be at a guess & I can't see why they would differ.
If you're not sure, just take your old one out & measure it. Then compare that size to the one you're ordering :iconwink:
Thats what I did before I ordered mine :)
HyChill hydrocarbon based refrigerants
Gidday Folks
If thinking about re-gassing, or your air-conditioning system needs it, consider this stuff -
HyChill refrigerant, which apparently works far better with systems that were originally designed for R12 refrigerant than does R134a.
It also happens to work better than R134a in systems that are designed for R134a ... Like about 30% better!! Lookie here:
https://www.hychill.com.au/
^ Seen a few scary and expensive situations at work with HyChill. Wouldn't touch it with a 10 foot pole. I highly wouldn't recommend it!
It is my job as an auto sparky to specialize in automotive refrigeration :iconwink:
Currently R134A has been around for 20 odd years in the automotive industry and works completely fine given your air conditioning system is healthy so I trust that.
I'm looking into retro-fitting A/C into the brumby...
Couldn't get hold of the Subaru evaporator cleaner: seems it never came to Oz.
Tried to get rid of the musty / muddy smell that came every time I turned on the AC: was told to run it hot to kill the bacteria / fungus, but this didn't work. Opened up the spot where the cabin air filter goes, and gave the evaporator a thorough steam clean. Got a can of Glen 20, sprayed the evaporator, and the air intake (outside under the windscreen) with the fan running: did this in each air flow position.
AC now much cleaner smelling, and seems to blow cooler air after the clean up.
"^ Seen a few scary and expensive situations at work with HyChill. Wouldn't touch it with a 10 foot pole. I highly wouldn't recommend it!
It is my job as an auto sparky to specialize in automotive refrigeration :iconwink:"
Like what? Or did a mate of a mate tell you this one..
