Ultimate Tire & Wheel Size Thread
I reckon you could go bigger. Unless there's no space to the spring perch as standard, because @bluesubaru 's configuration is only 10mm radius larger, assuming he's running 225/55R18 at the moment, then it's no closer to the strut than before either (give a mm). :)
This is true. Either way it'll be about $2kish for a wheel and tire package. So ill sit and save till I can afford it
