Rally
The 4 bolt to 8 bolt thing is I am told not an issue. I have even helped a mate do such a conversion on a GT Forester and no problems. But if it were me I'd like to have all the bolts in there.
While I can get this one for $200 inc wiring and replace the one specific valve and the heads, it's then good to go
I could have this one running for the price of that one :iconwink:
if the EJ25 heads were stuffed, you could do the EJ20 on the block and get yourself a compression boost. It's feasible and awesome, but would put you in a different category for auto repair/ mods/ knowledge/ and maintenance.
I think it's time that you checked out the frankenmotor on the USMB. PLENTY of info about that high compression engine in there. Most commonly done with a set of EJ22 heads but I'm sure the EJ20 heads will work just the same.
Like I said, plenty of info to read up on - this is not a modification for the light hearted. You need to understand what it is to look after it properly/repair it if the need ever arrives.
In my mind you've got 4 options:
1) EJ20 replacement engine
2) EJ22 long block retro fitted and run with the stock EJ20 ECU and wiring - some intake manifold mods might be needed if the EJ20 intake doesn't fit the EJ22.
3) EJ25 conversion - either a full wiring loom conversion or to stand out with something different with the frankenmotor using the bits you've got.
4) H6 conversion - again not for the light hearted.
The way I'm looking at it now is;
1. EJ20 replacement engine
2. EJ25 complete swap
3. EJ25 long block to replace my EJ20 long block and keep stock wiring, manifolds, etc. Using EJ20 heads if possible.
I want to look into option 3. The mechanic (Waggaclint on here) thinks that the manifold and sensors should bolt straight on from my EJ20 to the 25 LB. But again isn't 100% positive so I need to look into this. If this will work it means little down time on the car not having to do the wiring and would give me more power than the EJ20
How does that sound Bennie?
Even a good running 2.0 would be like a rocket compared to your 2.0.
I use 205/75/15 grabber tires and my 2.0 SF has no problem with 160km/ph on cruise controle on the german autobahn, even with some slopes in south germany and the LPG conversion I use and 350.000km on the odo
Imho a 2.0 isn't fast by far. But it's more than sufficient.
I think Taza runs his engines on beach sand. ;D
How's the hunt for your new engine going, any news yet ?
I got one but can't get it till mid Jan... It's 1/4 of the price that all the wreckers wanted too and I know the condition/history of it :iconwink:
Bet you can't wait till the end (mid) Jan :ebiggrin: And knowing the history is even better :iconwink:
Sounds interestingI also have some bolt on modifications to add a few extra hp too :iconwink:
Yeah I'm really excited. In the mean time I've been working on other stuff on the car. Dual Battery System, Under bonnet air compressor mounted, HID spotties, Stereo, Tidying wiring, Accessory camping lights, etc...
When the motor is in I will need the 2.0l computer to supply more fuel to the bigger 2.5l block. From what I've read on reliable tuning sitesm tuning a EJ25 N/A will give me around 130Kw and 245Nm of torque over the stock 115Kw and 223Nm. Then in comparison to my tied motor ~80-85Kw and ~165Nm. I also have some bolt on modifications to add a few extra hp too :iconwink:
Should give the car a heap of powerThen I can go proper offroad
Haven't been properly in over 4 months..
