- Jan 1, 2012
- 7,476
- Bayside, Melbourne, Vic
- MY06, MY10
- Forester SG & SH
- 5MT/DR & 4EAT Sports
G'day again Taz
A supercharger gives you an increase in power and torque that is exactly proportional to the boost. e.g. a 7 psi boost will lift power and torque at the same revs by 50% (approx, of course); 3.5 psi by 25%, etc.
There's your oil burning problem.
Replace the valves/valve guides and stem seals.
These being buggered has several effects:
Should be. But then I don't know what it's supposed to be :iconwink:.
Remember that the inlet and exhaust valves are both closed during the compression stroke. This means that the compression (and rings) can be excellent, but the problems you are having will be occurring.
Muzzle not the kine that tread the grain, mate! Even though I am a devout atheist, I have actually read the Bible. It sure has some good quotes in amongst the rest of it ...
When I sold Roo1, the plugs had done somewhere over 100,000 kms. However, it was rather sluggish over 150 km/h when passing (and fully loaded). 25,000 kms ought to be fine if you are using spec. NGKs.
On my last trip in it, I did about 4,300 kms and did not use a drop of oil or water. The air-conditioner ran for all but about 2~300 kms of that (35~40+°C ... ); with most of it just under 20 km/h over whatever the speed limit was (mostly ).
Ratbag, after having issues before hand and spending a few thousand on her im not replacing the engine. She just runs out of puff both on and offroad thus my reasoning for the SC, im not looking for turbo power either, just enough to have power on demand when its needed. From doing some calculations the SC should give me similar power to an EJ25 found in the eirlier Foresters but with more torque, mainly low down and in the mid range.
The valve stem/guide seals are completely r**ted, I have had a compression test done which came back almost like a new enigne on all 4 cylinder which means all the internals are fine.
- Excessive direct injection of oil into the cylinders when the valves are open on the inlet stroke;
- This oil is burned during the combustion (power) stroke; adding to carbon deposits throughout the internals of the engine; and causing the cops in the big city to pull you up and slap an "unroadworthy" certificate on you ... ;
- It also allows the sump to be pressurised during the exhaust cycle, forcing more oil up past the oil scraper rings - and more burned oil ...
- The additional oil during combustion leads to loss of power, and will also fool the combustion chamber sensor into firing the plug the second time at the wrong time ... This will lead to loss of power and torque.
Might try and clean a few of the sensors and just hope for some improvment.
From the compression test coming back at 230PSI on average for all 4 cylinder im guessing the rings are fine??
I know everything else is. She just burns through massive amounts of oil. I have gone through over 5L of oil just this year alone, in aorund 5000km!!
This can't be fixed though until the engine is out and apart, which will happen sometime this year. I need to chat to some of the Ausubaru guys in Perth and see if they can help.... don't really want to pay 10hours labour for a mechanic at $100 an hour.
If it were the sprk plugs wouldn't the engine just misfire and the likes? She used to run quite abit better mid last year even with the bigger tyres and roofs racks, etc... on the roof and front of the car.
The last time I changed the plugs was 25,000km ago or there abouts.
