Gidday ST & All
You're right of course Phiz, I don't know how much custom gears are but they must be 10 times what you paid for your 1.59 at least.
You don't get much for $42 usually.
In the early 1970s, I had a special set of final drive gears made for my Austin Kimberley. Increased the ratio from 16.9 mph/1000 revs to 22.5 mph/1000 revs (from approx 27 to 36 kmh/1000 revs in top).
FW Hercus Engineering in Adelaide made them. Cost $280 in 1974, IIRC.
That's a heap of money in today's terms - about $2,000+. These were helical cut sidewinder gears. Not under-engineered, either ... :iconwink:. FW Hercus reckoned they looked as if they came out of a Mack truck ...
The car had a 2.2L SOHC in-line 6 cylinder donk with bucket/shimmed tappets (no rocker arms/valve train lash ... ), with twin 1 3/4" SU carbies, cross flow head and extractors. Revved its rings off to over 7000 rpm. The FD gearing let it down badly. 4Spd baulk ring synchro box.
Knowing what I now know about torque curves and the like, I should have gone to at least the next step up, and possibly two steps up. Can't recall the ratio of the pinion to crown wheel in tooth numbers.
In any case, the change made a HUGE difference to the performance of the car, and dropped the revs at 100 kmh from around 4,000 to around 3,000. Fuel economy improved markedly, in spite of my then driving habits ... :iconwink:
