According to https://www.rimsntires.com/specs.jsp
225-60-17 has a diameter of 702 mm (27.6'').
215-70-16 has a diameter of 708 mm (27.9'').
So the difference is minimal. You can also do what others have done & "massage" the spare tyre well with a mallet or a hammer & a block of wood :biggrin:
Heathbar, that is a bugger bout your tyre but should be a cheap n easy fix...
I am now on 235/60/17 bfg long trails and they rub a bit on the front of the rear wells when the suspension is unweighted
(over big dips and big off camber drops) but they do look cool and are fine going down the highway.
On 16" rims though the tires would spread more if they are for offroad use, 17" would be very average offroad even with an AT tyre on. 15-16 inch would be the way to go. Plus you can gain more clearance and less chance of damaging a 17.
Sorry to dig up an old thread. I'm thinking of getting a set of at-s sent over from tirerack.com. They're about $150 each so still less than half the price you'd get them in Aus.
As with the OP, my MY10 Forester has standard Geolandar 225/55R17s but the AT-S comes in 225/60R17. That would make the diameter increase about 22.5mm which is slightly more than the 15mm allowed by law in Qld. On the other hand I could go with 215/60R17 which would only alter the diameter by 10mm and (I presume) keep me legal and insured.
Any idea what difference that 10mm off the width of the tyre is likely to make on or off road? Is it purely a visual thing with the car looking slightly taller and skinnier? If not, will the better tread and slightly higher ride outweigh the reduced width of the tyre? Will on road performance be compromised? I'm no speed demon but I like to throw the car around a roundabout now and then. Or as Taza suggests below, is it a waste of time trying to improve the tyres on a 17" rim. Should I just stick with my stock Geos or get a set of Coopers as I'm unlikely to change my rims to 16" or having a spare set just for off road use?
I presume that the more aggressive tread doesn't increase your on road fuel consumption noticeably does it? I know it's not too aggressive
no don't think i can legally, but i wont let that stop me.
From what I'm led to believe, you are allowed +/- 15mm of what's on the tyre placement card that's on the inside of your driver door.What's the law in NSW regards tyres? Can you go that size?
Thats so very true.Don't worry about the boys in blue so much ...
BUT be very afraid of voiding your insurance.
