... part two to follow
^ Absolutely love it, Greg :rotfl:.
I needed a good laugh. Thanks, mate :poke: :biggrin:.
Just did a trip to lake Albacutya / Wyperfeld / Big Desert / Lake Hindmarsh.
This was the first serious offroading since the new exhaust and the tune.
The vehicle has heaps of power and torque now: just eats through sand. The tracks were very chopped up because of the number of vehicles out there: convoys of 7, 8, 9 vehicles, and one convoy of 33 FJ cruisers:huh: As a result I got beached once and had to dig out: it was on a very steep and soft dune. I must say that the exhaust is very strong structurally, given that the vehicle was resting on it!
The side steps are a great addition: aside from making it easier to load the roof basket, they greatly reduce the amount of mud and sand splashed up the side of the car. very pleased with them.
It is however time for a rear suspension upgrade. I hit a dip too fast and completely nosed in, the rear end kicked up and came crashing down. the result was that I bent an OEM strut. Rather than replacing with OEM or the weaker KYB struts, I will go for a reinforced carrier and a serviceable koni insert like Kevin and Douglas Ferrier. I have had this in mind for some time, and had determined to do it when the rear struts gave out, which they now have. It will cost, but it will work very well.
No more heating issues ?
Nice Foz you have there Dulagarl !
Nope. No more heating issues. The new headers and exhaust have made a huge difference.
Awesome! Although I can't imagine waiting for 33 FJ Cruisers to slowly crawl by :rotfl:
Glad that the exhaust worked so well :biggrin:
Custom struts will make it even more of a beast! :lildevil:
So, the struts are coming along. Car should be ready in a couple of days.
So, some pics.
I wanted a few things done: long travel koni inserts, raised spring perch, reinforced body near bottom. Due credit to Kevin and Douglas Ferrier...
#koni2015
Instead of bolting them at the bottom, they will sit on a spacer to lift them. The inserts will be held in place by a collet with a screw top at the top. Here's the spacer:
here you can see the modified carrier: a collet at the bottom has been welded in place. You can also see where the spring perch as been moved:
Finally, you can see the carrier with the strut in it, and the collet that will be fitted to the top.
Won't be putting the King springs back in. Instead, I am getting custom springs made. The rear springs will be progressive, and allow a decent ride when unloaded, but the rear will take up about 20mm when loaded and the spring will be harder, if that makes sense.
Really looking forward to this...
Going all out mate! That's awesome.
Sorry to hear the torture of seeing 33 FJ cruisers in the same place at once. NO ONE and I do mean no one should ever be subjected to that. I'm surprised you survived the ordeal. Kudos to you!
Would've love to be out there with you but alas... Gearbox...
Do you have the full details on the struts? Ive bent both my rears on a sinilar hill climb.
I'll be going down the same path.
Who is making your progressive springs?
Only details I have are what I posted: raise spring perch 20mm, reinforce base with collet. They were OEM SG struts. The koni model number is in the pic.
Trutrack suspension have commissioned the springs: I don't know who their manufacturer is.
I found a thread that shows another way of doing it:
https://forums.nasioc.com/forums/showthread.php?t=1219607
Nice build Dulagarl but you won't gain any stroke, will you ?
yes, will gain stroke. I am told they have in the vicinity of 100 mm droop.
I agree with the first half of that...
not so much the second bit.
The struts are shaping up very well indeed Greg!
I reckon we need a new custom strut thread so people can find some of this very useful info...can it be copied into another thread rather than just moving it?
Good idea - once the build is done and if Greg agrees a copy or at least a link can be created.
Yeah that's fine with me: best wait til the job is done. That could take some time.....
Ralf (Trutrack) went into hospital on Sunday, and had his gall bladder removed yesterday. Says he'll be back at work tomorrow. Can't see it myself.
So, car has been there 4 weeks come monday. I hope I get it back next week.
At least the springs have arrived. All it needs now is assembly.
Maybe it will be done by "spring" ;-)
