... part two to follow
Ok cool. I would of thought you'd have more along the lines of 150-160kw at the wheels. Stock they have 180 at the crank with the ez30r, so around 110kw atw.
you'd be loving that increase in torque! The economy is pretty good too for a 6 cylinder.. got a pic of the dyno power?
Note there is no such engine as an EZ30R. It's an EZ30D.
Nice work with the exhaust, what a thing of beauty!
EZ30D doesn't have variable valve timing and overlap. It came in the 2000-2003 Outbacks while the later EZ30R came in the 03-09 outbacks and libs which was then replaced by the EZ36.
You'll need an exhaust similar in your L-series aye Andrew ;)
yes those are the differences between the two types of EZ30 motors, but they are both still called the EZ30D - there is no such subaru engine as EZ30R, there are just two different EZ30D's. People just commonly call the later version that as it's an easy differentiation and most of the later model cars with the later engine happen to be called the 3.0R.
If you mean that thing that appears before what I wrote about the outcome of the dyno run, yes. If you mean something else, no.
Technically correct, however it has come to be known as the R, simply because "R" is a bit easier to say than:
"theonewiththeplasticmanifoldandvariablecamandvariablevalveandoneexhaustportpercylinderinsteadofoneexhaustportperside."
The weight you have in the car doesnt affect dyno figures. In fact, with really high HP engines they often put a big fat bloke in the boot to keep traction :rotfl:
Your larger tyres will affect the figures though, changes the driveline ratio.
Main thing is you feel it has more torque and driveabilty :monkeydance:
^ thanks. I was wondering about that. What about LSD's?
I wouldn't think a LSD will make any difference to dyno figures. There's no extra loss of power, except perhaps a slight amount for the larger, heavier ones. Any difference would be very small
^ thanks. the reason I ask is that I noticed when the front LSD went in, I lost a little acceleration and economy.
Anyway, progress report:
Took vehicle out to lerdederg yesterday. Highway driving there was terrific. It really pulls up hills in 5th gear now.
The thing I am really amazed about is the improvement in cooling. I had eliminated the cooling "problems" some time ago, but it is even better now.
I initially thought my thermostat was stuffed, because of the large difference (up to 35 degrees) between engine coolant temp (ECT) as shown on the VIPEC software, vs the temperature of the thermostat housing as shown on the temperature watchdog. the former could show 95 degrees, and the latter only 60. Bear in mind that the H6 thermostat only fully opens at about 93 - 95 degrees. This was concerning as the fans are set to come on at 97.
Then voila: the thermostat opened. The ECT dropped progressively to 86, and the watchdog temp rose to about 82.
What was really amazing was that once that happened, the thermostat closed again, and we got back to the difference I described before. Better still, the same patter repeated when running the aircon on hills in 5th gear, and intake air temp (IAT) remained within about 6 degrees of ambient temp.
Once I got offroad, and was working hard in low range to go uphill, we got passed 100 degrees ECT and the watchdog was showing around 95, but once we stopped working hard temperatures quickly dropped.
I put this down to two things: 1: the tune means car is more efficient. 2: the really big factor I think is the reduced mass of the headers as compared to the originals. In short, the new headers heat up just as quickly as the old, but being less mass, they dissipate heat more quickly. This in turn reduces the amount of hear rising straight into the block. the reduced mass is because the old headers are three pipes per side, wrapped in mesh, and sealed in a pressed metal boot. the new headers are just three pipes per side.
To compare, when I first got the car it was prone to overheating on the flat on a hot day. Now, on a moderate day, I can run aircon with thermostat closed. I think i will be able to run aircon on a hot day in deep sand going up steep dunes. Can't wait to try it.
Very pleased with the latest mods: more power, more torque, more fuel efficiency and better cooling.
Damn mate, they're pretty good gain figures!
I think you'll find that the your theories on the exhaust is more about the exhaust gas velocity through the exhaust allowing an easier passage out to the back of the vehicle. You've obviously picked a good exhaust builder! I'm guessing he owns the shop, not just a grunt?
Sounds like you're pretty stoked. The sound file you text me didn't work too good, sorry for not replying until now :/
So, I need to get my gearbox sorted so we can go see if we can scratch you pretty exhaust!
Volumetric Efficiency? yeah, that too no doubt. But the mass of the headers really is a big issue.
You can check the sound file on the youtube I posted a link to.
Yeah, the exhaust builder owns the place with his father, and came highly recommended. They have done a terrific job.
Hurry up and finish the gearbox!
Got a hold of some steps from a wrecker. Pretty good condition, although the plastic end bits are a bit brittle. Will have to work out some sort of replacement for those.
Installed them this weekend: very easy job.
Much easier to access the roof basket now, and there are a few other advantages:
  • The old side skirts used to fill with sand and mud: not these.
  • Nice protection of the lower side of doors from gravel etc.
  • Good place to sit my can of beer while sitting under the awning on a rainy night.
I was wondering that too as I would like to look at an alternative to the brittle plastic side skirts but I don't want to lose clearance.
No, they don't reduce under sill clearance. Good design really.
Are they specifically made for the Forester or modified to fit?
Made specifically, they're pretty common on the jdm imports here.
Unlike the jdm foresters, yours has enough clearance that they look great!
^ yep. Always save the best til last.
Stumbled across a thread about the H6 transplant in the Dulagarl on a Russian site. Can't read Russian, but if you translate the page it makes for excellent reading.
https://forums.drom.ru/subaru/t1151389139.html
Some of my favourite translations are:
With fastening it easy. With the change of candles in all oppozitnik - difficulties, but not to the same extent that it is elevated to "unusable."
The eyes are afraid - the hands are doing. (C)
and
Wheelbarrow just Ladder. Hands grow from the right place. At least those in Krasnodar At least a couple. I would instead of the machine with a mind set muhaniku. And to whom the service station with the proposal does not address all the talking type, Ltd .. difficult though.
and
What the **** in the turbo or on the rocks? For ATV chase? They need a smooth pull in all the range, rather than kick after 3 thousand. Someone probably confuses forik for Rucker with forikom for ****.
and
certainly sensible person it is difficult to understand why loaf of white bread mold trolley.
no tires, no weight distribution, no overhangs, which moves in suspension and as posted - also niponyatno month train-load and go screw body, windshield burst, what nafig rock krovling on a solid McPherson? but he did not ditch the first move, you are rested the muzzle
ispahabili wheelbarrow!
I love it when Google translate can't handle things!
