... part two to follow
What a bugger! Let's hope there is no long term damage!
well, the chances of serious damage are very low. Basically it got a bit hot, and the weakest points let pressure out. the weakest points were:
  • hose connections: all hoses were replaced a year ago before the Nullarbor trip, and had the hose clamps had not since been tightened. One would usually tighten these after some repeated heating and cooling.
  • The weak spots in the radiator. the radiator was fairly worn out from what we can see, and it was simply a matter of (not much) time before it blew.
On that basis, since there were ample avenues for pressure to escape, it is highly unlikely that the head gasket was at issue. as well as that there were no performance issues, and no water in oil or vice versa.
New radiator has been sourced and is being fitted. This should improve any cooling significantly.
A cause for concern, but no major damage it seems. Lucky in a sense.
In other news, the panel beater has got back to me with his costs. Let's just say that I am happy with that outcome. :cool:
some good news for once
Radiator done, vehicle serviced, new steering boots, wheel alignment.
Just took it for a run. Running beautifully.
Gearing up for a trip up the Darling River and Paroo River. Might end up in Birdsville or Inamincka. leaving Tuesday is the plan, returning end of the month.
So, a bit of work has been necessary:
  • new brake pads all round
    new front discs
    new front driveshafts.
Also, yesterday I put it up on ramps and cleaned the underbody. It was filthy. the worst part was cleaning out the spring seats: they were full to the brim with Wimmera River mud that had dried rock hard. Seriously, if you put your hand in the spring seat it was full to the top. Took hours to clean it all out.
Today the plan is to fit the second cargo barrier, and get organised.
Also, bought a new set of headers with cat converters intact on ebay. These were from a gen 4 outback, so they are in really good nick. These will be kept as spares until I need them.
In other news, I also scored a new engine cover on ebay. Looks much neater than the original which was pretty rough.
Have a safe & enjoyable trip, mate.
Sounds terrific ... :ebiggrin: :biggrin:
A great time of year to be doing the trip.
Which way you going from the Paroo into Qld?
Will be interested in your adventures between Inamincka and Birdsville, as that section of road was closed when we were there.
Cordillo Downs Station , with the largest shearing shed in Aus is well worth a look, I understand.
Sounds wonderful; have a great time! Have a curried camel pie for me if you get to Birdsville!
The Dulagarl's life hangs by a thread made by actuaries and assessors.
It's in Dubbo, I'm in Melbourne. Lower trailing arm bolts at right hand rear have been ripped out of the chassis rail. I am told by a mate who knows that this should not be a huge deal to remedy, but the pressure is on the repairer to replace the whole rail.
If this is to be required in NSW, there is a chance it will be a repairable write off. I don't want this to happen in NSW. (does anyone know the rules in NSW on buying back the wreck? I have been told it has to go to public auction).
I am trying to arrange trucking it back to Vic to have it repaired, but am in a vicious circle with insurance. They say they want the NSW repairer to quote on the repair before they will agree to freight it: I say the NSW repair quote is irrelevant because the standards between Vic and NSW vary.
At worst, I have a quote for freight from Dubbo for just over $500. I may just pay that to get it here and stuff the hassle of arguing.
Stay tuned.
