There are at least three different versions of the DCCD that I am aware of. The first is the 5 speed one. Being the oldest, it lacks the refinement and efficiency of the later ones but beyond that I don't have all the details. A friend of mine has one in his 22B and he has being having issues with the controller. I'm not sure how well it locks up.
The second of the DCCD's came with the MY05 (ADM). It has a tendency to clunk when say going into and out of driveways, etc, but apparently works better than the 5 speed one.
The third one is the MY06 (ADM) onwards one, which is what I have, and it is very quiet and works the best of all of them. It incorporates a plated clutch as well as the DCCD. This means that if you want, you can just run the DCCD without a controller, although I do run a controller. With the controller set to manual, and with the setting set to give 50-50 split, it is as close to a locked diff as I think you can get. When I first installed the box, I did not know what the setting were like, and I inadvertently had set the diff in this setting. The car almost refused to turn around in the driveway. When I persevered ( I though I had adjusted the handbrake too far) there was an almighty bang, and the car moved. Nothing broke, but I never did that again!
I've not really driven a DCCD car in rocky conditions where wheel lifting is common. I compete in the WRX on wet motorkhanas, and in those conditions, the diffs are brilliant and the car responds instantly. Whether they would do the same off road I cannot be certain. From limited experience I think it might take a bit of time. An easier solution to the DCCD might be an 11kg centre diff, or if really keen, a 20kg one.
