Gidday Biesel
Realistically, the change is less than 10%. 4.10 stock to 4.44. So if you currently do 2500rpm say at 100kmph it would be like 27XX with the Ratio change.
It might even improve economey...
Not quite that simple ... :iconwink:
4.44/4.11 = 1.0803 increase in revs.
However, the increase in stress in any system is equal to the square of the increase in the stressor, in this case, the square of the increase in rpm.
Therefore the increase in stress is 4.44/4.11 = 1.0803, 1.0803^2 = 1.1670, or 16.7%.
Rally has an SG, so standard gearing in the FD is around 38 kmh/1000 rpm in fifth as things stand. Reducing the FD to 4.44 would decrease this to around 35 kmh/1000 rpm in 5th HR, i.e. around 2860 rpm instead of his current 2630 rpm.
This would decrease his fuel economy by a fair proportion of the amount that he would currently get driving on the highway at 100 km/h in 4th HR with his current FD gearing. Not as much, but it would be somewhere in there.
Even putting the 1.447:1 LR gears in, instead of leaving his 1.196:1 gear set there, will impact his ability to use LR for towing when not off-road. After looking at that bank he managed to drag his trailer up through, I don't think he needs to swap his LR gear set over either!
As Rally has already said, all these things involve compromises of some sort.
