NachaLuva
Product Developer
A while ago I got a 2" body lift kit from Crossbred Performance. Before I put it in I wanted to beef it up a little by boxing the open ended blocks & tieing the rear trailing arms together, also the front control arms.
So far:
The trailing arm blocks are on the left, they're also welded to the moustache bar blocks for extra stability. I put them on the car then tacked in the connecting 1"x1" RHS, then removed them & fully welded them. Some of the welds are a little rough but its strong.
I also replaced the bolts on the rear strut blocks with longer bolts to fit 1" spacers. A bit of a bugger as the longer bolts wouldn't go in so I had to make up some using HT threaded rod & HT nuts. The end result isn't neat but its strong & functional
The 28 plates I'll use to box in the blocks are along the front & took ages to cut
I also noticed a funny little triangular support on each side of the moustache bar:
It looks like their purpose is to stabilise the bar. Trouble is there's nothing in the lift kit for this. Would I need to fab up something or can I just leave this off? Its only thin pressed sheet metal with I think M6 bolts. The bar itself is held in place with substantial HT bolts so I'm not really sure why these plates are needed
So far:
