Part Two Fan Cutout
This is the wiring diagram. After reading up in my service manual and consulting with my subby Tech who is the best we bleave this is the best way to do this.
The reason for the lamp is so that there is a load on the circuit for the ECM to see. the lamp could be replace with a 12 volt buzzer or chime. Cut in the fans at the fan motor lead. the rest is where you want to ground the system and get you power for the lamp, buzzer or chime.
The fuse holder next to the switch is left empty, if the switch fails just install a 20 amp fuse so the fans will run till you replace the switch.
I will be installing this in a few days I need to get a deferent switch and a chime or buzzer and some other bits. For those who need photos I will post some after I install mine
If one does not want to install a lamp or buzzer, there is a way to trick the ECM. At least on the 2000 models. The fans must show that they are not working, on two consecutive drives to trip a trouble code. Drives means (Key on start run engine to temp. key off ). What you will need to do is after your done driving when you have used the fan cutout, wile the fans are running shut the off and restart the car with fans running shut car off. this will reset the counter in the ECM. If the fans are not running when you restart just turn on the AC that kicks the fans on.
If you get a code just reset it you know the fans are good.
To all that use this there is no guarantee and it may void your warranty!!!!!!
The codes that could show up are P0480, P0483 and P1520
Thanks Nate
