FOZTNQ
Agree with this being the more important. However would also agree with other comments of setting the same tyre pressures.Actually, if you think about it, it's probably the actual circumference that matters more. Even if the tyre pressures are different and the height of the wheel centre is a different, the tyre still has to roll over the ground, and so it's the circumference that matters. The tyre pressure probably does not matter. Maybe I'm just being pedantic here.
This may help with calculating things
Tyre Size Calculator
A better easy to use tyre size calculator. Use our tyre size calculator to find tyre diameter, width, sidewall, circumference, and revolutions per mile.
