Something wild is coming! Outback 2022 Wilderness X
not for slow steep off roads though.. until they make some new low gear transmission there .
think for most this Wilderness will be for some wild shoping nothing more.
The SJ is the last Forester that came with the low range here in the EUDM. So you should be able to find a dual range gearbox that fits your 2010 SJ....outside the US.
This Outback version uses the G015! I don't remember any G015s being released with white embossed letters before, though.
It's a 20min video but to skip the blah-blah, check out the time stamps.
It looks like they also tweaked the X-modes to be a bit more aggressive vs the Onyx they tested before.
thats as much wild as any other lifted subaru, but they allways makes new model as some different from older, when in most cases its not , they just dont compare it to older. i mean lift old subaru, put rear diff lock on there and then compare to any new subaru. that would be good comparisson.
i mean non turbo forester vs turbo outback why would you ever pick non turbo. ??
somehow it got less ground clearance vs outback wilderness too , maybe smaller tire or not same lift then. 9.2' vs 9.6' , and 180hp vs 260hp on outback
but then if you buy subaru and then will buy lift kit for it , so this is better version , allready prelifted.
