Oldcrow
- Joined
- Aug 20, 2017
- Messages
- 4
- Location
- Rochedale South
- Car Year
- 2010
- Car Model
- Outback
- Transmission
- 5
The single horns on my Outback and my Honda CB1300S are pathetic. I ordered a Fiamm Freeway Blaster and a Stebel High Power Magnum. The Fiamm is made in the USA and cost me about $35 delivered by Amazon from the USA. The Stebel is made in Italy and cost around $26 delivered and is readily available in my home town of Brisbane, Oz. Both horns have low tones.
The Fiamm is slightly more compact and louder so I mounted it on the Honda, I mounted the Stebel on the Outback. Both horns were easy to mount and come with mounting hardware. The Stebel and the Fiamm have two terminals and the Outback horn only has one. The Fiamm also comes with a connection to earth one of the terminals to the mounting bracket. I had to remove the plastic around the original Outback horn connector to get a good connection on the horn terminal.
A low cost and easy conversion with a high level of improved performance particularly if you get the Fiamm which I recommend.
