El_Freddo
- Aug 11, 2008
- 2,399
- Bridgewater, Vic
- 1988, 1990
- EJ22'd L series; Targa Brumby
- Locking FT4wd 5spd Manual, 4.111:1 diff w 1.59:1 low range & front OBX LSD ;)
G’day all,
On our new to us Foz - aka “The Yak”, the driver’s door will not open or lock the central locking system when using the key. Our fobs are dead and we’re not looking at those atm. The key use is the issue.
To open the whole car you need to open the driver’s door with the key, then use the central locking button to open all the doors.
To lock the car it’s the reverse process, except we can close the driver’s door by holding the door handle open it will be locked when closed (after using the central locking to lock all doors).
Our central locking system will lock and unlock the driver’s door via the interior button on the door.
What we want is to unlock and lock all doors with the key from the driver’s door.
My questions are:
- is this standard or do I have an issue?
- if this is not normal, what’s the fix?
It’s frustrating and could potentially result in the car having a locked driver’s door while the rest remain unlocked.
It would be nice to use the key to unlock the door and have passengers able to open their doors as you do after unlocking the car with the key.
Any insight or help would be great! I have everything out but can’t see any issues. And the actuator in the driver’s door is only a two wire unit. I thought there would be more for this unit to tell the rest of the system to lock or unlock too.
Thanks in advance!
My questions are:
Thanks in advance!
