El_Freddo
- Aug 11, 2008
- 2,399
- Bridgewater, Vic
- 1988, 1990
- EJ22'd L series; Targa Brumby
- Locking FT4wd 5spd Manual, 4.111:1 diff w 1.59:1 low range & front OBX LSD ;)
In videos it’s really hard to compare as the videos can be quite deceptive as to how hard the car is working, and how steep the terrain is too.If you or someone could show in videos comparison low ranges would be best visual info i think.
It’s best to be there if possible. You hear and sometimes feel vibrations in the air/on your clothing that you can’t get from watching a video, even if you have the best sound system! Like this video of mine:
We had an SG foz with 1.19:1 low range that struggled on this climb - initially the lines chosen weren’t great. Then the rocky outcrop climb after the corner had it stalled out and stuck. We snatched/dragged from there.
The other foresters with 1.447:1 did it alright too:
Hill start from previous video:
From each of these videos you can see just how differently each driver drove their vehicle over the same terrain, particularly the two SFs which are basically setup the same - both had EJ22s, two inch lift, gearing and roughly the same tyre size.
Going back to the terrain in videos, you would be surprised just how steep this climb was. You get some idea if you’re paying attention to it but the reality of it is that videos are never a good indication of how steep climbs actually are.
I hope this helps you out with a very rough comparison of the different low ranges.
All vehicles have 4.111:1 diff ratios, except the SG that *might* have 4.44:1 ratio - hopefully Nachaluva or 1wd will remember.
