Biolite Stove
Ben Up North
can only hope to improve
FNQ
2004 | 1992
SG Forester X MY05 | 92 SVX
5MT D/R | 4EAT
Has anyone seen one of these in action?
A friend of mine saw one at one of his friend's place. Apparently this guy has covered a fair stretch of the planet with one of these in tow (the friend of a friend is a photographer).
Would be a nice bit of kit to have in the Foz I reckon.
And it's less than a month to my birthday!
Isn't this just a wood stove with a fan in it ?
I prefer gas canisters -- cheap, readily available, high energy density, hot flame, clean burning, always work.
Pretty much. Much more efficent than a standard wood stove though (runs on twigs) plus it has 5V power output for charging.
I bet I could find more twigs in the middle of nowhere than you could find gas canisters too!
I remember when they first came out, the heat out put of the stove wasn't that great for cooking, but they may have improved that over time.
I run an Optimus Nova, which is a lightweight stove, which can run on multiple fuel sources (great when hiking internationally). It can even run on jetfuel! It also burns extremely hot, so cooking is fast - I've used massive 40l stock pots cooking for an entire campsite on it with ease
But SHY and her band of loonies won't let you destroy some poor little insects home though.
Pretty sure Political discussions are banned. But that is also not true, and classic propaganda you see splashed everywhere by the Murdock Media
Unfortunately for some reason even the intelligent get suckered in by what other people tell them. I don't know whether it's group think, bandwagon fallacy or what.
well - it happens to be true in most National Parks in NSW - not sure about other states.
I can't remember the last NP I went to where it wasn't prohibited.
Quote: Most parks also prohibit the collection of firewood for use within parks.
Oh look - also prohibited in Qld. I hope you take your own pile of sticks.
Never collect firewood or kindling from the park—everything, including dead branches, are protected by law.
I'm not considering this as a replacement for my current cooking equipment - the missus would kill me.
For me this would be like my PIRB, sits in the car and I hope I'm never in the situation to need it. Would probably slot in quite neatly between my recovery kit and my air-pump. With a couple of cords of home grown sticks even. ;)
Also, for what it's worth.. up here in the tropics, lots of forest. Not many people.
Have had the rangers come around to the campsites up here where people have got major logs burning away and no-one bats an eye. The way stuff grows up here is phenomenal (as is the way it's knocked down during cyclones), so I guess it's not heavily policed.
I'm not condoning the behavior, just stating the way it appears to be.
Interestingly, clearing away the some of the fallen timber after cyclone events actually helps the rainforest to recover and reduces the influx of weeds.
Saw this in couple camping videos, they where cooking some meal and charging phone. But i think to just have some external battery that can charge your phone 4-10 times is better simplier and cheaper. And for portable stove i would choose some foldabe one.
I've seen some nice mini rocket stoves, but they don't look like they'd last long. Mind you, the biolite doesn't look like it would last long, but this guy has had and used it for a couple of years at least.
I think all stoves that made from thin metal wont last long they would bend from heat, deform. But then then not made for large wood peaces to burn just something small inside. I like idea of something so small and portable and could still make you coffe and cook food. Will try to make myself one and try in camping.
Understood, @Ben Up North, my primitive caveman fire-starting survival skills were challenged when I was in the tropics. The twigs stay wet even when they were on the ground and broken off a tree for quite a while. I had to dry open twigs and some tips to be able to start fire that way. Moisture in the tropics is just phenomenal, making trees grow faster and healthier. Plenty of survival resources too.
I'd like to visit tropical OZ some time.
If you didn't get one for your birthday:
I have one and have used it a bit. The basic difference between the Biolite and other wood stoves is that the Biolite has a thermoelectric thingy, in other words, it generates electricity from the heat of the fire and keeps its internal battery charged up as you use it. And it has a fan/blower to push air over the fuel. It is essentially a small forge.
Pluses: You don't need to carry petrol or some type of gas as fuel; you can burn sticks, leaves, pieces of bark, etc. in it. I makes a great deal of heat, as good or better than a propane single burner stove. It doesn't require a lot of fuel and you can adjust the temperature with the fan control. You can use it to charge your phone or any device with a USB connector. Once it's up to temperature it barely smokes, if at all. The flame is hot enough to burn the vapors that make up smoke. It has accessories such as a small grill and a sort of kettle.
Cons: You have to monitor the fuel supply, keep feeding it fuel. One filling isn't enough to boil a liter of water. You need dry fuel but this isn't usually a problem as you can pick up dry stuff along the way and keep it in a sack or whatever. Once it's going well you could use slightly damp fuel but it will smoke. It takes a bit of care/practice to get it going, after all, you're making a fire. Some sort of fire starter is advisable, paper will work, otherwise you end up shaving slivers of wood or whatever to get it started. Not a real problem with a little practice. If there is a fire ban in place, as often happens in the summer in the southwestern US parks and national forests you can't use it.
I stopped using mine because of the fire bans and because monitoring the fuel & feeding more sticks in it required paying more attention than I wanted to early in the morning. Now I use a cheap propane single burner stove that uses gas canisters because it's legal during the fire ban and I'm rarely out long enough to need to carry several canisters, one will last the weekend.
It's good for extended trips so you don't have to carry your fuel and for people who are environmentally conscious. You could travel with it and not have to worry about finding the right kind of fuel in the country you land in since airlines won't let you carry fuel.
Some good information there. :)
I gave my new home made fan forced blower stove it’s first burn
Nice! Does the blower just go into the centre of the burn chamber, or does it go at an angle to create a bit of a vortex?
