You have a SG Forester which has the higher spring perch. 215/70/16 is by far the most popular size for lifted Foresters & with a 2" lift will fit without rubbing.
225/70/16 will also just squeeze in under the spring perch but you'll need to flatten the pinch weld behind the front wheels, possibly a little trimming in the rear too
For tyre regs, the 7% rule doesn't apply to Foresters or Outbacks in Victoria, NSW & Queensland. In these states, you're allowed tyres with 50mm bigger diameter giving 1" tyre lift. This is in addition to 50mm strut lift, ie 75mm total lift is completely legal! Unfortunately, this doesn't apply to other Subies or other states. Hopefully, as they keep updating the laws, all the other states will come into line
