mslatfly
- Jul 18, 2008
- 37
- Maryland, USA
- 2016
- 2.5i Outback Premium
- CVT
Can't disagree with that Apsilon.
The fact is I mostly use the Trangia. If you carry 2 burners (almost zero weight and volume) it is easy to lift out the finished one with tongs and drop in a filled one. (NEVER re-fill an 'empty' burner that is warm - in case you just can't see the metho flame!)
However, I've had the Optimus since the mid 1970's and there is nothing like the sound of a 'choofa' cooking away in the door of a tent on a snow camp in an otherwise silent universe. :ebiggrin: (With the escape valve pointed OUT, so you can't flame your home and yourself!)
Thank you both for the info. I didn't know that the Trangia would burn for 20 min. That's better than I was reading elsewhere. Oh, and yes, I figured it would be easy to carry a second burner as well.
Oh, and Barry, did you ever have the escape valve open while cooking? I've only ever had one problem with that type stove. It was on old US Army version of the older Coleman design (M-1951 Mountain Stove). The check valve at the bottom of the pump body failed. The pump filled with fuel, that then started squirting out, and ignited. Good thing there was a fire extinguisher close by. Didn't do any damage, replaced the check valve. Now it works like new again.
